Hi All,
I am trying to flash my NUCLEO-L053R8-T6 however when i do i get these errors:
https://imgur.com/a/am0rQfE
Any help would be great.
Do the ST-LINK Utilities or STM32 Cube Programmer think the parts on your board are any more legitimate? Check Keil side drivers/dlls are current.
Both softwares see it as a real ST product, which as far as i am aware it is. I tried another ST board and it works fine. I also tried the board that is not working on a differnt PC and it gave me the errors. Which is really strange.
Are you using the on-board ST-Link of the Nucleo?
Do you have a separate ST-Link or other debug probe to try ... ?
I am using the onboard ST-Link unfortunately i dont have a seperate ST-Link. What is strange, at least to me, is that it works if i use Mbed OS. so the board must be ok right? Just something is going on with it.
Thanks.
Or the mbed-os just doesn't care?
Good point!
If you're using MDK V5.28, see the following Knowledgebase Article: http://www.keil.com/support/docs/4139.htm
