hey guys, my keil have began to crush a while typing when trying to pre-comlite my data.. exactly when im typing TX ( in order to type TX_temp ...) it freeze for a long time .. then a black screen and later it back to work at usual . i cannot keep work like this and have no clow we its ocurr like this for the firs time .. i do have strong computer
Whenever you notice a crash of uVision, please immediately open a Support Ticket:
http://www2.keil.com/support/silver
and report the problem, but also all product- and Pack versions in use, thanks.
Beside, (I assume that you use Keil MDK ) do you see this crash:
- when using our latest release MDK 5.28 (offered at: http://www2.keil.com/mdk5 ) ?
- when using one of the example projects offered by the Pack Installer ?
What version? ARM/C51/C166 ?
Not sure it does a precompile, are you sure this isn't a problem with the auto-complete or browser information?
You could try unchecking the build browser information under the output options. Doing a clean rebuild. You could try disabling auto-complete.
Files on a server?
Would definitely recommend to migrate to uV 5.28a to avoid dealing with issues already addressed in prior updates.
Mine's quite heavy physically, what does that mean in the way of processor(s), memory, and operating system?
