We are using uVision V5.24.2.0 and PC-Lint Plus v1.2. As per the configuration instruction on Keil website we added the following lines to LNT file:
-hsb_3 -format="*** LINT: %(%f(%l) )%)%t %n: %m" -width(0,10)
We have added the option for the full file path "+ffn" also.
For some reason, Keil will not open the offending error/warning, it just gives a path error:
"c:\git\*** LINT c:\git\motor_controller.c conatins an incorrect path."
I though it might be the formatting option, so I change the PC-lint -format option to:
-format="%(%f(%l) )%)%t %n: %m"
I am getting the same path warning and the same output from PC-Lint in the output window.
Does anyone have a work around or run into the same issue?
Regards,
Chris W
