I have a project for an STM32L4. Today I updated the CMSIS RTOS2 Keil RTX5 from version 5.4.0 to 5.5.1.
If I debug in Keil with the old RTX5 version (5.4.0) I can see all stack and variable in the window "Call Stack + Locals". If I use the RTX5 latest version (5.5.1) I see only the idle and timer threads; no other threads, no call stack and no variable values.
Does anyone have the same problem? How can I fix?
Thanks, Antonio
Hi Antonio,
This is a known issue which is being fixed (will be part of the next MDK release).
Thank you for the response.
How can I find a list of open issues and also a way to report a new one?
To report bugs: http://www.keil.com/support/bugreport.asp
The corresponding patch to fix this issue in MDK v5.27 can be found here http://www.keil.com/support/docs/4124.htm
