#include<reg51.h> typedef unsigned int u16; void main() { P0=0x01; u16 i; }
Placing a statement declaring a new variable following a statement assigning an 8-bit IO port makes the compliler report the error
syntax error near 'u16', expected '__asm' 'i': undefined identifier
If exchange 'P0=0x01;' and 'u16 i;', the compiler won't report a error, why ? Is this a bug of the compiler?
As in most cases, it is not a compiler bug, but a user bug. This is not C++. Variable declarations 'after' code is not possible in C (on the same blocklevel).
