I am trying to convert .axf file generated by ARM microconverter microvision V5.26.2.0. I have followed the instruction in http://www.keil.com/support/docs/3213.htm%22. and entered the following command under the user tab. The entry was C:\Keil_v5\ARM\ARMCC\bin\fromelf.exe --bin --output=SND201V1.bin C:\Users\Bhal Laptop 2017\Documents\A Smart Node DECWG (SND) Program\SND M0 Software\SND201V1\Objects\SND201V1.axf which showed the full path to the SND201V1.axf file. (without the full path it could not find the SND201V1.axf file.) Now the error message is FromELF: creating hex file... After Build - User command #1: C:\Keil_v5\ARM\ARMCC\bin\fromelf.exe --bin --output=SND201V1.bin C:\Users\Bhal Laptop 2017\Documents\A Smart Node DECWG (SND) Program\SND M0 Software\SND201V1\Objects\SND201V1.axf Error: Q0466E: An output file can only be specified if there is a single input file Finished: 0 information, 0 warning and 1 error messages. ".\Objects\SND201V1.axf" - 0 Error(s), 0 Warning(s). Build Time Elapsed: 00:00:00
Weli, I have only a single input file ! so what should be done ? Thanks. Bhal
Try putting the full pathname of the input axf file (which includes spaces) inside double quotes.
Just don't do that!
www.avrfreaks.net/.../2048571
