Is there a trick to get the CAN middle-ware to catch 29 bit ids?
void CAN2_SignalObjectEvent (uint32_t obj_idx, uint32_t event) {
if (event == ARM_CAN_EVENT_RECEIVE) { // If receive event ... }
This code snipit works for 11 bit but not 29 bit?
Look if you have filter set up to receive extended ids?
