In the 2012-04-25 version of the LPC407x_8x_177x_8x.h that came with my recent download of the MDK ARM tools I discovered something odd about the definitions of some fields for the UART type definitions. Specifically, for UART types 0 and 1 the transmit holding register is an 8-bit value, but for UART type 4 it's a 32-bit value. I don't see any difference in the datasheet for these registers. The difference caused an issue for when creating a class member variable that pointed to this register; or rather, when assigning values to it using the header file.
For reference, this variables were declared in my class,
volatile uint8_t * pTHR; // ptr to MCU UART transmit holding register volatile uint32_t * pIER; // ptr to MCU UART interrupt enable register
but to make the compiler happy I had to do this in setup code for this class.
// save values needed for ISR and read/write methods if(info->comport==0){ nIntNum=UART0_IRQn; pTHR = &LPC_UART0->THR; pIER = &LPC_UART0->IER; }else if(info->comport==1){ nIntNum=UART1_IRQn; pTHR = &LPC_UART1->THR; pIER = &LPC_UART1->IER; }else if(info->comport==2){ nIntNum=UART2_IRQn; pTHR = &LPC_UART2->THR; pIER = &LPC_UART2->IER; }else if(info->comport==3){ nIntNum=UART3_IRQn; pTHR = &LPC_UART3->THR; pIER = &LPC_UART3->IER; }else if(info->comport==4){ nIntNum=UART4_IRQn; // This THR is defined differently in the KEIL supplied header, but not the data sheet. // Not sure why that is. You can only write 8-bit values to the THR. pTHR = (volatile uint8_t *)&LPC_UART4->THR; pIER = &LPC_UART4->IER; }else{ return false; }
Can anyone tell me why the THR for UART4 is defined as a 32-bit value, but all other UART THRs are defined as 8-bit values?
Thanks.
Is it a Keil file, or from NXP?
(whose name is in the copyright?)
