I am trying to understand STM32F4-Discovery startup code that is added automatically to Keil project. i.e.
github.com/.../startup_stm32f407xx.s
I am using Keil MDK v5. Everything is clear except the following portion:
;******************************************************************************* ; User Stack and Heap initialization ;******************************************************************************* IF :DEF:__MICROLIB EXPORT __initial_sp EXPORT __heap_base EXPORT __heap_limit ELSE IMPORT __use_two_region_memory EXPORT __user_initial_stackheap __user_initial_stackheap LDR R0, = Heap_Mem LDR R1, =(Stack_Mem + Stack_Size) LDR R2, = (Heap_Mem + Heap_Size) LDR R3, = Stack_Mem BX LR ALIGN ENDIF
My Questions are:
1. Whats the purpose of this portion? 2. How does it initializes Stack and Heap as it only load Stack/Heap addresses in R0-R3? 3. Where is __use_two_region_memory defined that is imported here?
I search a lot but couldn't find any proper explanation. Any clue/reference will be highly appreciable.
Take a look at the following pages which should answer your questions: infocenter.arm.com/.../index.jsp infocenter.arm.com/.../index.jsp
Thanks. The links are indeed very helpful.
