Hi, we have downloaded the trial version which is time limited for 30 days and limited to 32kB of memory. The trouble we have is every sample application is over 32kB of memory - usually around 45kB. So far, we have managed to run no projects in Keil, so we cannot really trial anything. Is there any workaround for this? Any help would be much appreciated. Thanks
What "trial" version?
There are only 4 versions listed:
MDK-Lite MDK-Essential MDK-Plus MDK-Professional
http://www2.keil.com/mdk5
None of them is time-limited
http://www.keil.com/demo/limits.asp
Some chip makers have their own special arrangements - you'd have to contact them for details.
"Is there any workaround for this?"
If you want to negotiate special terms for a bona fide evaluation, then you will have to contact Keil (or your distributor) direct. Contact details are at the foot of the page.
www2.keil.com/.../mdk5-getting-started.pdf
Page 11 discusses how to get a 7 day trial of the Pro version without any size limitations.
So where does the 30 days come from?
