Hello All, Am trying to make the STM32f411VEtx board into DFU mode from the Application code, so am trying to write the bootloader code, If any one is having code please share or please help me how to write the code and how to flash as well. i took a reference code from git and tried to adopt the code for STM32f4 but unable to flash the code via ST flash loader tool
Surely, ST would be the place to go for that?
ST certainly have Application Notes showing how to do bootloaders.
Hint: look for "IAP" (In-Application Programming).
Thanks for responding Will this IAP supports DFU via Micro USB. I tried to flash the code via UART1(PA9)using USB-TTY (COM port)
IAP will do whatever you program it to do, that's the genius of writing software. ST has DFU USB examples, and USART ones
The following C and Assembler provide a means to execute the boot ROM of STM32F2 and F4 parts. It sets a value in RAM and then resets, the reset catches this value and remaps the ROM and jumps into it.
startup.s
; Keil based example - Reset into boot loader - sourcer32@gmail.com ; From C ; extern void SystemReset(void); ; *((unsigned long *)0x2001FFF0) = 0xDEADBEEF; // Write a scratch location at end of RAM (or wherever) ; SystemReset(); // or NVIC_SystemReset(); Reset_Handler PROC EXPORT Reset_Handler IMPORT __main ;... LDR R0, =0x2001FFF0 ; Address for RAM signature LDR R1, =0xDEADBEEF LDR R2, [R0, #0] ; Read current STR R0, [R0, #0] ; Invalidate CMP R2, R1 BEQ Reboot_Loader ; Add other choices ;... ; Normal startup path LDR R0, =SystemInit BLX R0 LDR R0, =__main BX R0 ENDP ;... ; Vector into System Loader Reboot_Loader PROC EXPORT Reboot_Loader LDR R0, =0x40023844 ; RCC_APB2ENR LDR R1, =0x00004000 ; ENABLE SYSCFG CLOCK STR R1, [R0, #0] LDR R0, =0x40013800 ; SYSCFG_MEMRMP LDR R1, =0x00000001 ; MAP ROM AT ZERO STR R1, [R0, #0] LDR R0, =0x1FFF0000 ; ROM BASE LDR SP,[R0, #0] ; SP @ +0 LDR R0,[R0, #4] ; PC @ +4 BX R0 ENDP ; sourcer32@gmail.com SystemReset PROC EXPORT SystemReset ldr r1, =0xE000ED0C ; NVIC Application Interrupt and Controller ldr r0, =0x05FA0004 ; Magic str r0, [r1, #0] ; Reset b . ENDP ;...
Now accepting PayPal, Venmo and Amazon Gift Cards..
So I need to merge the DFU example code into IAP right? The flash loader tool is expecting a bin file which am not able to generate. UART1 tx,rx is connected with USB-TTY (com port) and trying to access the device but tool is not responding
