I am trying to start a project with STM32F469NIH6 processor, which is definitely supported by the Keil toolchain. But, after i install all the relevant software packs the device won't appear in the 'option for target' under the device tab. There is nothing I can select in that tab. As a result when I try to build the program i get the following error:
Error: *** Project 'testProject', Target 'testProject', Device 'STMicroelectronics::STM32F469NIHx' is not supported by Toolchain ! ***.
I have tried to uninstall and reinstall Keil to no avail. I use STMCube32MX to generate the project. Everything worked fine when I was using a STM32L0 board.
Any suggestions on how to solve this please?
Make sure that you have installed: - Keil::STM32F4xx_DFP 2.13.0 and selected: STM32F469NIHx as Target.
In my test project I succeeded to build my application for a STM32F469NIH6 target.
If the problem persists, open a Support Ticket: www2.keil.com/.../silver
