I'm going to use TCP/IP stack from RL-ARM Library.
What I would like to know is what I need to do to be able to receive more then one connection.
I have seen a conceptual and partial example that supports my thread as follows: www.keil.com/.../rlarm_tn_tcp_mulconn.htm
I have also looked at another thread which summarizes that; it is possible to have Multi Client TCP/IP Server without RTOS via RL-TCPnet. www.onarm.com/.../
However, I could not see an executable example to properly understand how to catch multiple connections in the callback function.
Do you have any examples or outlines to suggest me to start at some point?
I know that Keil presents much more IOT protocol - based examples; however, neighter Keil's example directory nor on the web there is an (Multi Client TCP/IP Server without RTOS - preferably) example found..
Any help is appreciated.. Kind Regards Sarp
