I am using Keil-uVision v5.25 with 7-day MDK_ARM Professional (EVAL) (mdk_pro_eval). I am trying to build a project, but unfortunately it is giving me a error which states as below,
Error: C9555E: Failed to check out a license. Check that your license details are correct in the License Management dialog of MDK. Additional information is available at: http://www.keil.com/support/man/docs/license/license_management.htm If you need further help, provide this complete error report to your supplier or license.support@arm.com. - ARMLMD_LICENSE_FILE: unset - LM_LICENSE_FILE: unset - ARM_TOOL_VARIANT: unset - ARM_PRODUCT_PATH: unset - Product location: C:\Keil_v5\ARM\sw\mappings - Toolchain location: C:\Keil_v5\ARM\ARMCC\Bin - Selected tool variant: mdk_pro_eval_flex - Checkout feature: mdk_pro_eval_armcompiler - Feature version: 5.0201709 - Flex error code: -158 Product: MDK Professional 5.25 (Evaluation) Component: ARM Compiler 5.06 update 6 (build 750) Tool: ArmCC [4d3637]
I got to know from several threads that the 7-day professional license does not work with v5.24 or v5.24a with Arm compiler v5.06. Threads also suggested to upgrade the Keil version to v5.25, but even after updating the tool it still gives out the same error.
I request someone to help me out on this as soon as possible.
Thanks in advance.
Regards, Nithin
Did you follow the link in that error message?
For licensing issues, you need to contact Keil direct.
The forum is not a means to contact Keil direct - see the notes here: http://www.keil.com/forum
