how to use single wire can with middleware.
I'm trying to set up a 33333 bus that uses a single wire for can. Took a bit to get the 33333 configured but now it seems to have issues with receiving. Putting a break point at CAN2_SignalObjectEvent's checks never triggers. This set up below is for a dual wire CAN, do I need to combine the RX/TX to make it work for single wire? How would I go about this?
#define  CAN_CONTROLLER2         1       // CAN Controller number (can 1 is pa12/11) (can 2 is pb12/13)
#define _CAN_Driver_(n)         Driver_CAN##n
#define  CAN_Driver_(n)        _CAN_Driver_(n)
extern   ARM_DRIVER_CAN         CAN_Driver_(CAN_CONTROLLER2);
#define  ptrCAN               (&CAN_Driver_(CAN_CONTROLLER2))
uint32_t                        rx2_obj_idx;
uint8_t                         rx2_data[8];
ARM_CAN_MSG_INFO                rx2_msg_info;
uint32_t                        tx2_obj_idx;
uint8_t                         tx2_data[8];
ARM_CAN_MSG_INFO                tx2_msg_info;
static int ID_Read;
static int _TIMEOUT = 100;//each 100 is a second
void CAN2_SignalUnitEvent (uint32_t event) {
  switch (event) {
    case ARM_CAN_EVENT_UNIT_ACTIVE:
      break;
    case ARM_CAN_EVENT_UNIT_WARNING:
      break;
    case ARM_CAN_EVENT_UNIT_PASSIVE:
      break;
    case ARM_CAN_EVENT_UNIT_BUS_OFF:
      break;
void CAN2_SignalObjectEvent (uint32_t obj_idx, uint32_t event) {
  if (event == ARM_CAN_EVENT_RECEIVE) {         // If receive event
    if (obj_idx == rx2_obj_idx) {                // If receive object event
      ptrCAN->MessageRead(rx2_obj_idx, &rx2_msg_info, rx2_data, 8U);
                        ID_Read = rx2_msg_info.id;
        printf("single caught:ID_Read &i \n", ID_Read);
  if (event == ARM_CAN_EVENT_SEND_COMPLETE) {
    if (obj_idx == tx2_obj_idx) {
bool CAN2_Initialize (int CAN_BITRATE_NOMINAL) {
  ARM_CAN_CAPABILITIES     can_cap;
  ARM_CAN_OBJ_CAPABILITIES can_obj_cap;
  int32_t                  status;
  uint32_t                 i, num_objects, clock;
  can_cap = ptrCAN->GetCapabilities ();
  num_objects = can_cap.num_objects;
  status = ptrCAN->Initialize    (CAN2_SignalUnitEvent, CAN2_SignalObjectEvent);
  if (status != ARM_DRIVER_OK) { return false; }
  status = ptrCAN->PowerControl  (ARM_POWER_FULL);
  status = ptrCAN->SetMode       (ARM_CAN_MODE_INITIALIZATION);
  clock = ptrCAN->GetClock();
        if ((clock % (10U*CAN_BITRATE_NOMINAL)) <= 300U) {
                        status = ptrCAN->SetBitrate    (ARM_CAN_BITRATE_NOMINAL,
        ARM_CAN_BIT_PROP_SEG  (1U) |
        ARM_CAN_BIT_PHASE_SEG1(5U) |
        ARM_CAN_BIT_PHASE_SEG2(3U) |
        ARM_CAN_BIT_SJW       (1U));
  else if ((clock % (8U*CAN_BITRATE_NOMINAL)) == 0U) {
                                    ARM_CAN_BIT_PROP_SEG  (5U) |
                                    ARM_CAN_BIT_PHASE_SEG1(1U) |
                                    ARM_CAN_BIT_PHASE_SEG2(1U) |
  } else if ((clock % (10U*CAN_BITRATE_NOMINAL)) == 0U) {
                                    ARM_CAN_BIT_PROP_SEG  (7U) |
  } else if ((clock % (12U*CAN_BITRATE_NOMINAL)) == 0U) {
                                    ARM_CAN_BIT_PHASE_SEG1(2U) |
                                    ARM_CAN_BIT_PHASE_SEG2(2U) |
                                    ARM_CAN_BIT_SJW       (2U));
  } else {
    return false;
  rx2_obj_idx = 0xFFFFFFFFU;
  tx2_obj_idx = 0xFFFFFFFFU;
  for (i = 0U; i < num_objects; i++) {
    can_obj_cap = ptrCAN->ObjectGetCapabilities (i);
    if      ((rx2_obj_idx == 0xFFFFFFFFU) && (can_obj_cap.rx == 1U)) { rx2_obj_idx = i;        }
    else if ((tx2_obj_idx == 0xFFFFFFFFU) && (can_obj_cap.tx == 1U)) { tx2_obj_idx = i; break; }
  if ((rx2_obj_idx == 0xFFFFFFFFU) || (tx2_obj_idx == 0xFFFFFFFFU)) { return false; }
  status = ptrCAN->ObjectSetFilter(rx2_obj_idx, ARM_CAN_FILTER_ID_EXACT_ADD, 0xfff, 0U);
  status = ptrCAN->ObjectConfigure(tx2_obj_idx, ARM_CAN_OBJ_TX);
  status = ptrCAN->ObjectConfigure(rx2_obj_idx, ARM_CAN_OBJ_RX);
  status = ptrCAN->SetMode (ARM_CAN_MODE_NORMAL);
  return true;
void CANWrite_MS (int ECU, unsigned char data[], char noReply)
        _LEDON (BLUE);  osDelay(1);_LEDOFF (BLUE);
//      sendCompleted=false;
        if (!noReply) ID_Read=0;
  memset(&rx2_data, 0U, 8);//clear data.
  memset(&tx2_msg_info, 0U, sizeof(ARM_CAN_MSG_INFO));
  tx2_msg_info.id = ECU;
        ptrCAN->MessageSend(tx2_obj_idx, &tx2_msg_info, data, 8U);
long CANRead_MS (int ECU, unsigned char data, char position)
        memset(&command_Data, 0U, 8);
        for (int t=0;t <_TIMEOUT;t++)
                osDelay(10);
                printf("read:ID_Read &i \n", ID_Read);
                if (ID_Read > 0)
                        if (ECU == 0 )
                                memcpy(&command_Data, &rx2_data,8);
                                if (data != 0)
                                        if (command_Data[position] == data) return ID_Read;
                                } else return ID_Read;
0
