Bad block management using Keil middleware I am trying to see whether bad block management for NAND flash is done by default with the below combination of hw/sw. Would be great if anyone can help on this.
processor : STM32F4 Flash device: Micron MT29F2G16ABAEAWP The below packs are used CMSIS – 5.2.0 Compiler – 1.3.3 Middleware – 7.5.0 Device drivers – 2.11.0
You might check this out: www.keil.com/.../nand_flash__t_l.html
