Dear all,
I use the SAME70 that is a 300MHz Cortex M7 device with a JLINK Debugger. I tried to use the trace facility with no success. As soon as I switch on the trace facility the startup 'hangs' in the function dbg_task_switch(). I assume it is related to the CPU core clock setting. However it is unclear to me how to do it. The device starts at 4MHz, then it get usually switched to 120MHz and finally to 300MHz. I found a note on the KEIL website saying that you should adjust the clock manually just before the clock is switched. However that is very slow and time intensive and also I the corresponding entry in the dialog box is grayed out in debug mode. So it's not possible to change it. Anyone using successfully the trace feature with the JLINK Debugger on a SAME70?
Best Regards Markus
