Hi everyone,
I have an 8051 boot loader for in-system programming. I have a command protocol that allows me to read and write to flash, XRAM, and IRAM over the in-system communications interface (e.g. UART). I would like to add the four pages (0x00, 0x10, 0x0f, and 0x0c) of SFRs, but of course they can only be accessed directly, not indirectly.
Does anyone have a clever way of taking e.g. an SFR address in the range of 0x80 to 0xff as an input and returning the value of the SFR?
The best idea I have at the moment is a jump table, indexed by (addr-0x80), where each entry is a pre-programmed get/set of the corresponding SFR, followed by a jump to the end (effectively a 128-entry switch statement). Assuming I do the SFR paging and any loop management externally, the smallest I can see to shrink this is 3 bytes per entry (MOV A, addr ; RET), for 384 B to cover the full 128 B address space.
Speed is not of particular importance for this particular application, but code space is.
Cheers, -Lance
Whoops, I sometimes forget not everyone is using identical devices. For reference, I am using one of the SiLabs C8051 series devices with flash banking and SFR paging.
If you can configure your hardware to allow XRAM to be mapped to code space and you can write to that XRAM, then maybe worth considering some self modifying code.
Your best bet would be: don't do that. Seriously.
But if you absolutely have to, the most space-efficient way this can be done, assuming your hardware can be set up that way, is self-modifying code. Copy the code bytes for
MOV A, 0x80 RET
into a 3-byte absolutely located section of von-Neumann mapped XRAM, overwrite the '0x80' byte with the SFR address you want, and call that snippet.
I don't really understand what it means, but since you got two people say the same thing in quick succession, it would be sensible to at least consider the idea.
Agreed. However, I do not believe it is possible to map XRAM (or other RAM) onto code space on SiLabs 8051 devices. Or, put another way, I believe the instructions fetch only from internal flash memory, which is a separate memory space from IRAM, which is separate again from XRAM.
In theory I could re-progam the flash memory on the fly, but that's a non-started since this is intended to be a very reliable boot loader.
SFR access is definitely a "nice-to-have", I'm just trying to see if there's anything that can be done before dismissing it entirely.
when I have needed :incirect SFR" I have used a state machine switch (type) case 0: SFRa = 47 break; if 1: SFRb =47 ......
Well, given your description "SiLabs 8051 devices" covers somewhere between 360 and 646 different devices, you'll have to find that out for yourself. Nobody else is going to slog through hundreds of datasheets for you. At least not for free.
Whoa slow down there.. I wasn't asking anyone to slog through anything. I'm simply saying the suggested remapping approach will not work in this case.
Allow me to rephrase to be more explicit: you cannot remap XRAM onto code space on any SiLabs 8051 device of interest to me.
