I'm reprograming a customer old PCB's with LPC2138 ARM7 MCU's using Segger jlink with JTAG wires, all OK. I'm viewing that, If I use global or function static vars debugging is not posible, but in the other hand, I can simulate with no problems.
Look:
int pep = 0;
int main (void) { int cnt;
for(;;){ ++pep;
for(cnt=LOOP_CNT; cnt; cnt--) ;
the compilation is right and if I compile, debug and follow step by step the assemble the program resets at scatterload_zeroinit.
Anyone was the same problem?
Thank you.
Keil 5.24 with legacy support enabled.
