chip st32f205
I followed this guide www.keil.com/.../ulink2_trace_itm_viewer.htm and I get no output in the debug view, if I change the coreclock I see garbage in the debug view but at 120.000000 I see nothing. I had this working before. Not sure what also to look for.
The problem seems to be the start up, once i loop my project code for a bit it starts to work. Not sure what the delay is all about?
