I have a code that I'm trying to debug with Keil uvision4 .
I set up the project for simulator debugger. However, when I click "Debug" it always goes to the .s file but never enters the c code
So hit the stop button and see where it is stuck!
Chances are it is in some SystemInit() code looping for some hardware that doesn't exist, ie clocks, PLLs, etc.
Don't use the simulator in areas it doesn't fully support, better yet use real hardware.
it doesn't even go to the C code !!!
when i click on 'run' the first time it goes to the assembly file then the space in front of these lines become green the second time i click on run nothing change and i can't click on run again as if it is still running
Reset_Handler PROC GLOBAL Reset_Handler ENTRY IMPORT __main LDR R0, =__main BX R0 ;Branch to __main ENDP
Then press STOP and see where it is stuck, or frankly STEP INTO the code and follow what is happening. Debugging about having a clue about what is going on.
The processor doesn't run C code.
I am not an informatic engineer so i may not grasp the meaning behind all these concepts. I apologize if i didn't fully understand your answer or may be i didn't succeeded in explaining my problem to know where is the bug i have to go step by step or do some breakpoints usually when i try to debug my project , which is composed of a .s file where i define my vector table and a c. code that contains my algorithm, when i go step by step the space in front of each executed line become green and so on until i find the bug however in my case not a single instruction was executed. Even if my "code is looping for some hardware that doesn't exist"
at least there are some instruction that should be working fine my first code line is
A = (0.7854 * D*D); //cross section area
