hi Everybody,
please guide me how to configure and code a STM32F4 as SMBus master within KEIL UVision.
regards, Rasool
is it possible?
The code is the same whatever IDE you use - or even if you don't use an IDE at all.
So what is your actual question?
Are you asking how to use uVision?
www2.keil.com/.../learn
http://www.keil.com/support/man_arm.htm
Or are you asking about the STM32F4?
www.st.com/.../stm32f4-series.html
i am searching a tutorial example on STM32F4 SmBus master with KEIL UVision.
Micro-controllers are more similar than they are different, read around the topic and triangulate.
www.st.com/.../jcr:content/translations/en.DM00118362.pdf
www.st.com/.../x-cube-smbus.html
www.maximintegrated.com/.../476
kevinzhengwork.blogspot.com/.../stm32-smbus-example.html
