How to observe the SPI Signals(MOSI, MISO, SCK, and CS) Using the logic analyzer available in keil. I have tried to add the spi signals by using pin definitions, port address pin data address but all say no signal found. I am able to only add the variables I defined in the program. Do I need to do any additional setting for to be able to use logic analyzer for spi or i2c?
Thank you.
Hi did you find out how to do it, I am also facing the same problem
