STM32L433CCT6 Flash Algorithm
I have an STM32L433CCT6 and appears that there no Algorithm for this device, it would appear from data sheets that this memory is different form other devices.
Are there any Algorithm downloads for this device.
Help would be appreciated.
Kind Regards John W
  • Hi ... Not sure if gave all information.
    I am using uVision 5.23 and have updated Packs.
    Have tried a number of Algoriths for ST 256K Flash.
    Some do not not respond, some Download Code but then Read Errors.
    Have anyone used the above device before via uVision.
    I have generated code via STMCube this compiles in uVision OK, but does not download correctly. If any one can help I would be grateful as I have produced a PCB for this device.
    KR John W
  • The flash algo for this device is located in your keil installation directory:
    \Keil_v\ARM\Pack\Keil\STM32L4xx_DFP\1.4.0\Flash\STM32L4xx_256.FLM
    Have you installed the Software Pack for this device using Pack Installer ?
    If yes, then you should be able to select the flash algo for this device under:
    Options for target -> Debug -> Settings -> Flash Download -> Add
