I am working on file system middleware component to interface the SD card with lpc1768.I double checked all the resource requirements and configuraton of all the components required.Still, fmount function returns the fsMediaError and is unable to amount the memory drive.I have no clue of the issue. Can anyone please help me out on this ?
Am using the code given below to initialize and mount the sd card.
void sd_init(void) {fsStatus stat; SystemInit(); LPC_GPIO2->FIODIR=0XFFFFFFFF; printf ("Initializing and mounting enabled drives...\n\n"); /* Initialize and mount drive "M0" */ stat = finit ("M0:"); if (stat == fsOK) { stat = fmount ("M0:"); if (stat == fsOK) { LPC_GPIO2->FIOPIN=0xfffffff1; printf ("Drive M0 ready!\n"); } else if (stat == fsNoFileSystem) { /* Format the drive */ LPC_GPIO2->FIOPIN=0xfffffff2; printf ("Drive M0 not formatted!\n"); } else if (stat==fsMmediaError){ printf ("Drive M0 mount failed with error code %d\n", stat); LPC_GPIO2->FIOPIN=0xfffffff3; } } else { printf ("Drive M0 initialization failed!\n"); } printf ("\nDone!\n"); }
As far as initialization of the pins related to the SPI interface, it should be taken care of by middleware only.Isn't it so? I have referred the SPI driver to be used in the configuration file.This initialization part resembles with the code given in File Systems demo given in the lpc device pack.
Can anyone please help out ?
Scope the SPI to see if its doing what you think it should be doing.
There's no value in saying the middleware has set it up. If it's not working then there must be something wrong. A developer's skill set includes knowing how to narrow down a problem to a specific area. Stop assuming someone has a simple answer snd just do it.
I am not having any debugger.How to trace the SPI without it?
Invest in a cheap logic analyser then. Look on sites like aliexpress or ebay. If you can't afford that then you could maybe slow the SPI right down and use LEDs to try and see if there's at least life. Or write a little code to monitor the SPI lines and report their state. If you can't do any of that then you'll have to dream up another scheme.
Actually, I am thinking to buy a debugger only but not able to find out which one will perfectly suit my purposes.I am doing my graduation right now, so not a professional developer. So, am right there in the gradual process of learning.Can you suggest me any?
Then, surely, your university must have suitable equipment in the labs?
Honestly don't you understand how to present a problem in a way that can be solved?
You've mentioned a chip, but not a board, you've provided no circuit diagram or details of connectivity. There is no code or settings here indicating how the pins are being configured, or how the peripherals are being clocked or anything. Engage your brain and make a complete and thorough presentation of the system and the software as it currently stands.
Hi, I am having what may be a similar issue, just moved over to keil from microelecktronika compiler and have working application but now i am trying to get to grips with keil.
SETUP: STM32F407VG, SD card connected to SPI3, CS connected to Port D Pin 3.
Used STM32CubeMX and selected SPI3 as Port c, pins 10, 11, 12. Set PD3 as GPIO Output. Clock is 25MHZ xtal and PLL to 150MHZ
RTX operating system, 1 Blinking task with an led connected to PB0 flashing every second. During this second i try and mount SD Card but it is failing with fsMediaError.
Have checked the card and its file system is ok, tried multiple cards and same result.
Also created function to set CS pin as shown
int32_t fs_mc_spi_control_ss (uint32_t drive_num, uint32_t ss){ if (ss==1) HAL_GPIO_WritePin(GPIOD,GPIO_PIN_3,GPIO_PIN_SET); else HAL_GPIO_WritePin(GPIOD,GPIO_PIN_3,GPIO_PIN_RESET); return ss; }
My writefile function is as below;
void WriteFile() { fsStatus st; if (finit("M0:") == fsOK) { st=fmount("M0:"); if (st == fsOK) HAL_GPIO_TogglePin(GPIOB,GPIO_PIN_1); ; } FILE *f=fopen("try.txt","a"); if (f!=NULL) { HAL_GPIO_TogglePin(GPIOB,GPIO_PIN_2); fprintf(f,"Test\n"); fclose(f); } }
The purpose of the toggle pins is to see if it worked.
I am not looking for someone to fix this but a pointer in the right direction would be really much appreciated.
Consider if the pin is active LOW
Yes, if you mean in the CS code, have tried both.
still no difference.
I am sure i am missing something silly, this has been puzzling me for about 70 hours at this point.
int32_t fs_mc_spi_control_ss (uint32_t drive_num, uint32_t ss){ if (ss==0) HAL_GPIO_WritePin(GPIOD,GPIO_PIN_3,GPIO_PIN_SET); else HAL_GPIO_WritePin(GPIOD,GPIO_PIN_3,GPIO_PIN_RESET); return ss; }
about ready to give up and continue on with the Mikroelektronika, where I have written FTP, HTTP, SD Card logging etc. Went to keil as I thought they had built in functions etc and I would like to use the RTOS.
I have probed with a scope and spi3 is not working, no clock signals etc. I am baffled and just dont know what to do.
I am wondering what fmount does before it starts up spi, as no matter if i set spi3 clock active high or low I do not get a signal on the clock line. always seems to be floating.
Any ideas?
The obvious place to start would be that the SPI3 peripheral clock is enabled, on the right APB, and that you have the pins correctly configured. So the AHB clock for the GPIO, and the Alternate Function of SPI3 selected.
Have tried all of this, just cannot get sd card to mount.
I have followed this app note http://www.keil.com/appnotes/files/apnt_273.pdf to the letter but still does not work on spi3.
Has anyone managed to get STM32F407VG working with SD card on spi3?
Likely to be very few in a hijacked LPC1768 thread.
I don't suppose SPI3 is magically different from SPI1 or SPI2 in this context. Try presenting the board/chip specific code, the devil is in the detail.
