Hi all,
LPC4078, uVision 4.74.0.22, TCPnet/Net_Config.c v4.72
I have a bug in my release code that is very occasional and disappears when I change anything so I can't debug it or add debug prints or whatever.
I have a small bootloader that optionally receives an application via Ethernet and programs it into higher ARM flash then runs it. One combination of bootloader and app show the problem - occasionally. I'm looking for something that can be set by the bootloader then persists when the app runs. Both the bootloader and the app call init_TcpNet.
1) Is it safe to call init_TcpNet a second time?
2) Is it safe to call init_TcpNet a second time from another program which may have different settings such as number of UDP sockets? There is of course no reset between them.
Thanks Ant
