Recently we have changed the micro-controller from STM32L152 to STM32L162.
The issue is, when using the debugging the "Peripherals Viewer" is empty on STM32L162.
But if I am changing the Device back to STM32L152 the "Peripherals Viewer" works.
Is any way to repair it quickly?
If you have a Keil licence, you can contact Keil direct for support.
Hello Andrew Neil, We do have 3 Keil licences. Can you please, share the contact information?
Go on - bottom of the page ...
See also: http://www.keil.com/forum/
Hello Alexey,
Thank you for using the Keil tools for ARM.
It sounds like you are looking at the System viewer window see: µVision User's Guide: System Viewer
And don't see any peripherals.
The system viewer window is automatically generated from a System Viewer Description (SVD) file, that is provided by the CMSIS-Pack Author (in this case ST).
I used a text editor to look in the Pack Description file (PDSC) for this family of chips:
C:\Keil_v5\ARM\PACK\Keil\STM32L1xx_DFP\1.2.0\Keil.STM32L1xx_DFP.pdsc
It looks like the STM32L152 devices have SVD entries:
<debug svd="SVD/STM32L15xC.svd"/>
... but the STM32L162 devices do not have SVD entries.
I would check with ST about this.
As a work around you could use a use a SVD file from a 152 device in your 162 project.
You could edit an existing file, as described in this Knowledge base article:
(Keil KB) SWPACK: Kinetis interrupts shifted in NVIC window
..or you could follow the Adding the peripheral register file to the project steps on this page
µVision User's Guide Adding System Viewer Window
