Hi I am trying to flash mk64fn1m0vll12 (http://www.keil.com/dd2/freescale/mk64fn1m0vll12) this is available as a board by name Freedom-K64F
When I try to flash the board using KEIL I get the following error
Spend a lot of time searching on web but no success. Can someone help me
Contents mismatch at: 0000001FH (Flash=00H Required=DFH) ! Verify Failed! Error: Flash Download failed - "Cortex-M4"
More details:
Target info: ------------ Device: MK64FN1M0VLL12 VTarget = 3.300V State of Pins: TCK: 0, TDI: 0, TDO: 0, TMS: 0, TRES: 0, TRST: 1 Hardware-Breakpoints: 6 Software-Breakpoints: 8192 Watchpoints: 4 JTAG speed: 1429 kHz
Full Chip Erase Done. Programming Done. Contents mismatch at: 0000001CH (Flash=00H Required=C4H) ! Contents mismatch at: 0000001DH (Flash=00H Required=DCH) ! Contents mismatch at: 0000001EH (Flash=00H Required=FCH) ! Contents mismatch at: 0000001FH (Flash=00H Required=DFH) ! Verify Failed! Error: Flash Download failed - "Cortex-M4" Flash Load finished at 13:07:59
