I made a FFT program that takes data from inside a buffer, performs FFT, and spits out the equation form. The C89 (ported from C99) version works well, but when I use the EMF8LB1 board to run it after compiling/linking with C51, the output is different. Why is this happening?
I've compared the codes side by side and as far as I can tell there are no meaningful differences. I can provide .map, .asm, etc. files for the C51 version if that helps.
C89 version:
// Function: _fft // Uses divide and conquer (Cooley-Tukey) to turn buf (L terms of DTS) into Xk for freqeuncies wK = 2*PI*K/L void _fft(float bufreal[], float bufimag[], float outreal[], float outimag[], int step) { int i; if (step < BUFSIZE) { _fft(outreal, outimag, bufreal, bufimag, step * 2); _fft(outreal + step, outimag + step, bufreal + step, bufimag + step, step * 2); // Do small-size for (i = 0; i < BUFSIZE; i += 2 * step) { int j; float treal = outreal[i+step]*cosf(-PI*i/BUFSIZE)-outimag[i+step]*sinf(-PI*i/BUFSIZE); float timag = outimag[i+step]*cosf(-PI*i/BUFSIZE)+outreal[i+step]*sinf(-PI*i/BUFSIZE); printf("\nOut: "); for (j = 0; j < BUFSIZE; j++) if (!outimag[j]) printf("%g ", outreal[j]); else printf("(%g, %g) ", outreal[j], outimag[j]); printf("\ni: %d; step: %d", i, step); printf("\nout[i+step]: ( %g, %g )", outreal[i+step], outimag[i+step]); printf("\nt: ( %g, %g )", treal, timag); bufreal[i / 2] = outreal[i] + treal; bufimag[i / 2] = outimag[i] + timag; bufreal[(i+BUFSIZE)/2] = outreal[i] - treal; bufimag[(i+BUFSIZE)/2] = outimag[i] - timag; } } } int main() { //PI = atan2(1, 1) * 4; // Define PI float bufreal[BUFSIZE] = {1, 0, -1, 0, 1, 0, -1, 0, 1, 0, -1, 0, 1, 0, -1, 0}; // Dummy input float bufimag[BUFSIZE] = {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0}; float mag[BUFSIZE/2]; float phs[BUFSIZE/2]; float outreal[BUFSIZE]; // Create a copy of data float outimag[BUFSIZE]; //showcplx("Data: ", bufreal, bufimag); int i; float bufsize_dbl = (float) BUFSIZE; float sampleLength = (BUFSIZE/SAMPLERATE); printf("\rData : "); // Print string // Loop through and print for (i = 0; i < BUFSIZE; i++) if (!bufimag[i]) printf("%g ", bufreal[i]); else printf("(%g, %g) ", bufreal[i], bufimag[i]); for (i = 0; i < BUFSIZE; i++) { outreal[i] = bufreal[i]; outimag[i] = bufimag[i]; } _fft(bufreal, bufimag, outreal, outimag, 1); // magnitude(bufreal, bufimag); // Loop over all terms of buf less than folding frequency for (i = 0; i < BUFSIZE/2; i++ ) { mag[i] = (float) 2/bufsize_dbl*sqrtf( bufreal[i]*bufreal[i] + bufimag[i]*bufimag[i] ); // Come through too small magnitudes if ( mag[i] < THRESH ) mag[i] = 0; } // phase(bufreal, bufimag); // Loop over all terms of buf for ( i = 0; i < BUFSIZE/2; i++ ) { // No magnitude case -> phase = 0 if ( bufreal[i] < THRESH && bufreal[i] > -THRESH && bufimag[i] < THRESH && bufimag[i] > -THRESH ) phs[i] = 0; // 90 degree case (real = 0, imag > 0) else if ( bufreal[i] < THRESH && bufreal[i] > -THRESH && bufimag[i] > THRESH ) phs[i] = 0.5*PI; // 180 degree case (real < 0, imag = 0) else if ( bufreal[i] < -THRESH && bufimag[i] < THRESH && bufimag[i] > -THRESH ) phs[i] = PI; // 270 degree case (rea = 0, imag < 0) else if ( bufreal[i] < THRESH && bufreal[i] > -THRESH && bufimag[i] < -THRESH ) phs[i] = 1.5*PI; // All other cases including 0 degree case else phs[i] = (float) atan2f(bufimag[i], bufreal[i]); } // showcplx("\nFFT : ", bufreal, bufimag); printf("\nFFT : "); // Print string // Loop through and print for (i = 0; i < BUFSIZE; i++) if (!bufimag[i]) printf("%g ", bufreal[i]); else printf("(%g, %g) ", bufreal[i], bufimag[i]); // sinusoid(); printf("\n\n\n"); // Make some space // Loop over all terms of mag and phs for ( i = 0; i < BUFSIZE/2; i++ ) { float omega = 2*PI*i*(1/sampleLength); // No magnitude case if ( mag[i] == 0.0 ) continue; // Do nothing for that term // DC term case else if ( i == 0 ) printf("%f", mag[0]); // No phase case else if ( phs[i] == 0.0 ) printf("+%fcos(%ft)", mag[i], omega); // Normal case else printf("+%fcos(%ft+%f)", mag[i], omega, phs[i]); } return 0; }
C51 version is a carbon copy but with all variables in xdata.
Thanks to everyone in advance!
C51 version:
// Function: _fft // Uses divide and conquer (Cooley-Tukey) to turn buf (L terms of DTS) into Xk for freqeuncies wK = 2*PI*K/L void _fft(float bufreal[], float bufimag[], float outreal[], float outimag[], int step) { int xdata i; //int xdata j; if (step < BUFSIZE) { _fft(outreal, outimag, bufreal, bufimag, step * 2); _fft(outreal + step, outimag + step, bufreal + step, bufimag + step, step * 2); // Do small-size for (i = 0; i < BUFSIZE; i += 2 * step) { int xdata j; float xdata treal = outreal[i+step]*cosf(-PI*i/BUFSIZE)-outimag[i+step]*sinf(-PI*i/BUFSIZE); float xdata timag = outimag[i+step]*cosf(-PI*i/BUFSIZE)+outreal[i+step]*sinf(-PI*i/BUFSIZE); printf("\nOut: "); for (j = 0; j < BUFSIZE; j++) if (!outimag[j]) printf("%g ", outreal[j]); else printf("(%g, %g) ", outreal[i], outimag[i]); printf("\ni: %d; step: %d", i, step); printf("\nout[i+step]: ( %g, %g )", outreal[i+step], outimag[i+step]); printf("\nt: ( %g, %g )", treal, timag); bufreal[i / 2] = outreal[i] + treal; bufimag[i / 2] = outimag[i] + timag; bufreal[(i+BUFSIZE)/2] = outreal[i] - treal; bufimag[(i+BUFSIZE)/2] = outimag[i] - timag; } } } int main() { //PI = atan2(1, 1) * 4; // Define PI float xdata bufreal[BUFSIZE] = {1, 0, -1, 0, 1, 0, -1, 0, 1, 0, -1, 0, 1, 0, -1, 0}; // Dummy input float xdata bufimag[BUFSIZE] = {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0}; float xdata mag[BUFSIZE/2]; float xdata phs[BUFSIZE/2]; float xdata outreal[BUFSIZE]; // Create a copy of data float xdata outimag[BUFSIZE]; //showcplx("Data: ", bufreal, bufimag); int xdata i; float xdata bufsize_dbl = (float) BUFSIZE; float xdata sampleLength = (BUFSIZE/SAMPLERATE); printf("\rData : "); // Print string // Loop through and print for (i = 0; i < BUFSIZE; i++) if (!bufimag[i]) printf("%g ", bufreal[i]); else printf("(%g, %g) ", bufreal[i], bufimag[i]); for (i = 0; i < BUFSIZE; i++) { outreal[i] = bufreal[i]; outimag[i] = bufimag[i]; } _fft(bufreal, bufimag, outreal, outimag, 1); // magnitude(bufreal, bufimag); // Loop over all terms of buf less than folding frequency for (i = 0; i < BUFSIZE/2; i++ ) { mag[i] = (float) 2/bufsize_dbl*sqrtf( bufreal[i]*bufreal[i] + bufimag[i]*bufimag[i] ); // Come through too small magnitudes if ( mag[i] < THRESH ) mag[i] = 0; } // phase(bufreal, bufimag); // Loop over all terms of buf for ( i = 0; i < BUFSIZE/2; i++ ) { // No magnitude case -> phase = 0 if ( bufreal[i] < THRESH && bufreal[i] > -THRESH && bufimag[i] < THRESH && bufimag[i] > -THRESH ) phs[i] = 0; // 90 degree case (real = 0, imag > 0) else if ( bufreal[i] < THRESH && bufreal[i] > -THRESH && bufimag[i] > THRESH ) phs[i] = 0.5*PI; // 180 degree case (real < 0, imag = 0) else if ( bufreal[i] < -THRESH && bufimag[i] < THRESH && bufimag[i] > -THRESH ) phs[i] = PI; // 270 degree case (rea = 0, imag < 0) else if ( bufreal[i] < THRESH && bufreal[i] > -THRESH && bufimag[i] < -THRESH ) phs[i] = 1.5*PI; // All other cases including 0 degree case else phs[i] = (float) atan2f(bufimag[i], bufreal[i]); } // showcplx("\nFFT : ", bufreal, bufimag); printf("\nFFT : "); // Print string // Loop through and print for (i = 0; i < BUFSIZE; i++) if (!bufimag[i]) printf("%g ", bufreal[i]); else printf("(%g, %g) ", bufreal[i], bufimag[i]); // sinusoid(); printf("\n\n\n"); // Make some space // Loop over all terms of mag and phs for ( i = 0; i < BUFSIZE/2; i++ ) { float xdata omega = 2*PI*i*(1/sampleLength); // No magnitude case if ( mag[i] == 0.0 ) continue; // Do nothing for that term // DC term case else if ( i == 0 ) printf("%f", mag[0]); // No phase case else if ( phs[i] == 0.0 ) printf("+%fcos(%ft)", mag[i], omega); // Normal case else printf("+%fcos(%ft+%f)", mag[i], omega, phs[i]); } return 0; } <\pre>
C89 version output (verified to be correct)
Data : 1 0 -1 0 1 0 -1 0 1 0 -1 0 1 0 -1 0 Out: 1 0 -1 0 1 0 -1 0 1 0 -1 0 1 0 -1 0 i: 0; step: 8 out[i+step]: ( 1, 0 ) t: ( 1, 0 ) Out: 1 0 -1 0 1 0 -1 0 1 0 -1 0 (5.89021e-039, 1) 2 (16, -1) 2.24208e-044 i: 0; step: 8 out[i+step]: ( 1, 0 ) t: ( 1, 0 ) Out: 2 0 -1 0 2 0 -1 0 0 0 -1 0 0 0 -1 0 i: 0; step: 4 out[i+step]: ( 2, 0 ) t: ( 2, 0 ) Out: 2 0 -1 0 2 0 -1 0 0 0 -1 0 0 0 -1 0 i: 8; step: 4 out[i+step]: ( 0, 0 ) t: ( 0, -0 ) Out: -1 0 0 0 -1 0 0 0 -1 0 0 0 -1 0 (5.89021e-039, 4) 2 i: 0; step: 8 out[i+step]: ( -1, 0 ) t: ( -1, 0 ) Out: -1 0 0 0 -1 0 0 0 -1 0 (5.89021e-039, 4) 2 (16, -1) 2.24208e-044 8.99954e-039 5.88424e-039 i: 0; step: 8 out[i+step]: ( -1, 0 ) t: ( -1, 0 ) Out: -2 0 2 0 -2 0 0 0 0 0 0 0 0 0 (1.01064e-038, 2) 2.32438e-017 i: 0; step: 4 out[i+step]: ( -2, 0 ) t: ( -2, 0 ) Out: -2 0 2 0 -2 0 0 0 0 0 0 0 0 0 (1.01064e-038, 2) 2.32438e-017 i: 8; step: 4 out[i+step]: ( 0, 0 ) t: ( 0, -0 ) Out: 4 0 -4 0 0 0 0 0 0 0 0 0 0 0 0 0 i: 0; step: 2 out[i+step]: ( -4, 0 ) t: ( -4, 0 ) Out: 4 0 -4 0 0 0 0 0 0 0 0 0 0 0 0 0 i: 4; step: 2 out[i+step]: ( 0, 0 ) t: ( 0, 0 ) Out: 4 0 -4 0 0 0 0 0 0 0 0 0 0 0 0 0 i: 8; step: 2 out[i+step]: ( 0, 0 ) t: ( 0, -0 ) Out: 4 0 -4 0 0 0 0 0 0 0 0 0 0 0 0 0 i: 12; step: 2 out[i+step]: ( 0, 0 ) t: ( 0, -0 ) Out: 0 -4 0 0 0 0 0 0 0 0 0 0 0 0 0 (5.89021e-039, 4) i: 0; step: 8 out[i+step]: ( 0, 0 ) t: ( 0, 0 ) Out: 0 0 0 0 0 0 0 0 0 0 0 (5.89021e-039, 4) 2 (16, -4) 2.24208e-044 8.99954e-039 i: 0; step: 8 out[i+step]: ( 0, 0 ) t: ( 0, 0 ) Out: 0 0 0 0 0 0 0 8 0 0 0 0 0 0 0 1.01064e-038 i: 0; step: 4 out[i+step]: ( 0, 0 ) t: ( 0, 0 ) Out: 0 0 0 0 0 0 0 8 0 0 0 0 0 0 0 1.01064e-038 i: 8; step: 4 out[i+step]: ( 0, 0 ) t: ( 0, -0 ) Out: 0 0 0 0 0 0 0 0 0 0 0 0 0 (5.89021e-039, 4) 2 (16, -4) i: 0; step: 8 out[i+step]: ( 0, 0 ) t: ( 0, 0 ) Out: 0 0 0 0 0 0 0 0 0 (5.89021e-039, 4) 2 (16, -4) 2.24208e-044 8.99954e-039 5.88424e-039 8.99963e-039 i: 0; step: 8 out[i+step]: ( 0, 0 ) t: ( 0, 0 ) Out: 0 0 0 0 0 8 0 0 0 0 0 0 0 1.01064e-038 2.32438e-017 8.9994e-039 i: 0; step: 4 out[i+step]: ( 0, 0 ) t: ( 0, 0 ) Out: 0 0 0 0 0 8 0 0 0 0 0 0 0 1.01064e-038 2.32438e-017 8.9994e-039 i: 8; step: 4 out[i+step]: ( 0, 0 ) t: ( 0, -0 ) Out: 0 -4 0 0 0 0 0 0 0 0 0 0 0 0 0 (5.89021e-039, 4) i: 0; step: 2 out[i+step]: ( 0, 0 ) t: ( 0, 0 ) Out: 0 -4 0 0 0 0 0 0 0 0 0 0 0 0 0 (5.89021e-039, 4) i: 4; step: 2 out[i+step]: ( 0, 0 ) t: ( 0, 0 ) Out: 0 -4 0 0 0 0 0 0 0 0 0 0 0 0 0 (5.89021e-039, 4) i: 8; step: 2 out[i+step]: ( 0, 0 ) t: ( 0, -0 ) Out: 0 -4 0 0 0 0 0 0 0 0 0 0 0 0 0 (5.89021e-039, 4) i: 12; step: 2 out[i+step]: ( 0, 0 ) t: ( 0, -0 ) Out: 0 0 0 0 0 0 0 0 8 0 0 0 0 0 0 0 i: 0; step: 1 out[i+step]: ( 0, 0 ) t: ( 0, 0 ) Out: 0 0 0 0 0 0 0 0 8 0 0 0 0 0 0 0 i: 2; step: 1 out[i+step]: ( 0, 0 ) t: ( 0, 0 ) Out: 0 0 0 0 0 0 0 0 8 0 0 0 0 0 0 0 i: 4; step: 1 out[i+step]: ( 0, 0 ) t: ( 0, 0 ) Out: 0 0 0 0 0 0 0 0 8 0 0 0 0 0 0 0 i: 6; step: 1 out[i+step]: ( 0, 0 ) t: ( 0, 0 ) Out: 0 0 0 0 0 0 0 0 8 0 0 0 0 0 0 0 i: 8; step: 1 out[i+step]: ( 0, 0 ) t: ( 0, -0 ) Out: 0 0 0 0 0 0 0 0 8 0 0 0 0 0 0 0 i: 10; step: 1 out[i+step]: ( 0, 0 ) t: ( 0, -0 ) Out: 0 0 0 0 0 0 0 0 8 0 0 0 0 0 0 0 i: 12; step: 1 out[i+step]: ( 0, 0 ) t: ( 0, -0 ) Out: 0 0 0 0 0 0 0 0 8 0 0 0 0 0 0 0 i: 14; step: 1 out[i+step]: ( 0, 0 ) t: ( 0, -0 ) FFT : 0 0 0 0 8 0 0 0 0 0 0 0 8 0 0 0 +1.000000cos(12.566371t) Press any key to continue . . .
C51 output (not the same values for some reason):
Data : 1.000000 0.000000e+00 -1.000000 0.000000e+00 1.000000 0.000000e+00 -1.000000 0.000000e+00 1.000000 0.000000e+00 -1.000000 0.000000e+00 1.000000 0.000000e+00 -1.000000 0.000000e+00 Out: 0.000000e+00 0.000000e+00 0.000000e+00 0.000000e+00 0.000000e+00 0.000000e+00 0.000000e+00 0.000000e+00 0.000000e+00 0.000000e+00 0.000000e+00 0.000000e+00 0.000000e+00 0.000000e+00 0.000000e+00 0.000000e+00 i: 0; step: 32 out[i+step]: ( 1.000000, 0.000000e+00 ) t: ( 1.000000, 0.000000e+00 ) Out: 1.000000 0.000000e+00 -1.000000 0.000000e+00 1.000000 0.000000e+00 -1.000000 0.000000e+00 1.000000 0.000000e+00 -1.000000 0.000000e+00 1.000000 0.000000e+00 -1.000000 0.000000e+00 i: 0; step: 64 out[i+step]: ( 0.000000e+00, 0.000000e+00 ) t: ( 0.000000e+00, 0.000000e+00 ) Out: 0.000000e+00 0.000000e+00 0.000000e+00 0.000000e+00 0.000000e+00 0.000000e+00 0.000000e+00 0.000000e+00 0.000000e+00 0.000000e+00 0.000000e+00 0.000000e+00 0.000000e+00 0.000000e+00 0.000000e+00 0.000000e+00 i: 0; step: 128 out[i+step]: ( 0.000000e+00, 0.000000e+00 ) t: ( 0.000000e+00, 0.000000e+00 ) Out: 0.000000e+00 0.000000e+00 0.000000e+00 0.000000e+00 0.000000e+00 0.000000e+00 0.000000e+00 0.000000e+00 0.000000e+00 0.000000e+00 0.000000e+00 0.000000e+00 0.000000e+00 0.000000e+00 0.000000e+00 0.000000e+00 i: 0; step: 256 out[i+step]: ( 0.000000e+00, 5.911820e-39 ) t: ( 0.000000e+00, 0.000000e+00 ) FFT : (1.000000, 1.000000) 0.000000e+00 -1.000000 0.000000e+00 1.000000 0.000000e+00 -1.000000 0.000000e+00 (1.000000, -1.000000) 0.000000e+00 -1.000000 0.000000e+00 1.000000 0.000000e+00 -1.000000 0.000000e+00 0.176776+0.125000cos(6.283185t+3.141592)+0.125000cos(12.566371t)+0.125000cos(18.849554t+3.141592)
You'll want to double-check that fact. Get a file comparison tool, and use it.
Remember that Keil C51 has many "tricks" to make standard 'C' work on the weird and restrictive 8051 architecture.
So make sure you are in "pure ANSI" mode - and not using any of the special options such as disabling integer promotion ...
Apart from that, just run up 2 instances of uVision and step through the 2 code versions side-by-side in the simulator ...
C51 version is a carbon copy but with all variables in xdata. by large model or by specifying at variables?
if by large model, you have DRAMATICALLY changed the timing, could it be an ISR ?
BTW why ?
I did it at each variable i.e. char xdata hello_world.
Thanks everyone for the responses, I ended up replacing the recursive algorithm with a brute force iterative one, since there was not enough ram on my EFM8 to hold the stack required by the recursive algorithm. Now everything works.
You do realise that you can't just do recursion in C51 as in Standard 'C', don't you?
That's one of the "tricks" I referred to earlier.
http://www.keil.com/support/man/docs/c51/c51_le_reentrantfuncs.htm
