I am trying to establish a build environment for existing work space. I have HEX file generated from another environment(uVision 3 on windows 10).
I have installed the same tool chain on XP SP3. Built the work space and generated HEX file. The toolchain versions are similar in both environment. The project configurations/options are similar in both environment.
When i compare the two HEX files, i am seeing lot of difference between them. Why? Should not it be same? Since toolchain and project configurations are same. What else is dependency here?
Could someone please clarify.
Thanks.
Thanks Weston for suggestion.
Found that some difference in processor external libraries. That has caused the HEX difference.
I have installed the same tool chain on XP SP3. Built the work space and generated HEX file. The toolchain versions are similar in both environment. The project configurations/options are similar in both environment. the key is 'similar'. to get identical, you need identical
