I'm trying to use the IAP routine to change the active flash bank on an LPC4357 with uVision V5.15. The application uses the Ethernet Network interface and the CMSIS-RTOS RTX. Does anyone know the correct way to disable interrupts before calling the IAP routines and then how to re-enable the interrupts? The code ends up in the HardFault Handler after the eth_thread starts running again.
uint8_t IAP_SetBootFlashBank(uint8_t bankNum) {
uint32_t command[6], result[5]; uint32_t interrupts[8]; uint32_t i; //disable interrupts SysTick->CTRL &= ~(SysTick_CTRL_TICKINT_Msk); for (i=0;i<8;i++) {
interrupts[i]=NVIC->ISER[i];
NVIC->ICER[i]=interrupts[i];
NVIC->ICPR[i]=interrupts[i];
} __disable_irq(); command[0]=49; command[1]=0; command[2]=0; command[3]=0; iap_entry(command, result); //initialise IAP command[0]=50; command[1]=0; command[2]=0; command[3]=0; iap_entry(command, result); //prepare sector 0, bank 0 for write command[0]=50; command[1]=0; command[2]=0; command[3]=1; iap_entry(command, result); //prepare sector 0, bank 1 for write command[0] = 60; command[1] = bankNum; command[2] = SystemCoreClock / 1000; iap_entry(command, result); //re-enable interrupts __enable_irq(); for (i=0;i<8;i++) {
NVIC->ISER[i]=interrupts[i]; }
SysTick->VAL = 0; SysTick->CTRL |= (SysTick_CTRL_TICKINT_Msk); return result[0]; }
