if I set the visual vertical size of the uVision IDE C/C++ window to a size of 100 lines in uVision V4.50 then setting the V5.25 IDE to the same vertical size it only shows 85 lines. Both IDE are set to Lucida Console size 8. The line spacing differs. I like to use the old fashion style (100 lines). Is there any solution to this?
Thanks in advance.
Does it only happen when you set the height to 100 lines?
I dragged the V4.50 window vertical until 100 lines were visible. Then I dragged the V5.25 to the same vertical size showing only 85 lines. So the line-spacing has increased to 118%.
