MCB1700 SNMP_Agent & HTTP Server example not able to access Board IP
I have mcb1700 Eval Board on which i am trying to run example code SNMP_Agent as well as HTTP server.
I have set jumper E/U to use P2.9 as ENET_MDIO & E/C to use P2.8 as ENET_MDC so that i can use ethernet connection.
In both case as per abstract.txt i used crosslink network cable to connect PC & MCB1700 board.
I am using static ip 192.168.0.1 for my pc.
In both cases i am not able to access MCB1700 with IP "19.168.0.100".
I tried to ping MCB1700 but got host unreacheable.
Anyone have tried these example pl let me know where i am going wrong ? Any soln for this ?
Thanks in advance.
0
