Register Variable
hi
i want to migrate from arm compiler 5 to 6
compiler 5 uses for following local variable a register (e.g. r0) register unsigned long len;
compiler 6 does not
why?
which keyword should i use therefore
  • You can't!
    As stated in the language specification, the 'register' keyword is merely a hint - the compiler is in no way obliged to take any notice of it.
    Again, if you really need to do this kind of micro-optimisation, then you should be writing in assembler.
    Have you looked at the optimisation settings provided by the compiler ?
  • Hi
    thanx for the answer
    My problem is, that the support for compiler 5 will end in 2020. So for new projects i have to migrate to compiler 6.
    But the new compiler 6 creates a lot of inefficient code and the size of my image inreases from 530kb to 890kb (compiling with -O0 with C5 and C6)
    Example: d = (unsigned long*)&Image$$ARM_LIB_STACK$$ZI$$Base; len = STACKSIZE >> 2; while (len--) *d++ = 0xCCCCCCCC;
    C6 makes
    ER_CODE:80002C0A MOV R0, #0x2001C000
    ER_CODE:80002C12 STR R0, [SP,#0xC+var_8]
    ER_CODE:80002C14 MOV R0, #0x4000
    ER_CODE:80002C1C LSRS R0, R0, #2
    ER_CODE:80002C1E STR R0, [SP,#0xC+var_C]
    ER_CODE:80002C20 B loc_80002C22
    ER_CODE:80002C22 loc_80002C22
    ER_CODE:80002C22 LDR R0, [SP,#0xC+var_C]
    ER_CODE:80002C24 SUBS R1, R0, #1
    ER_CODE:80002C26 STR R1, [SP,#0xC+var_C]
    ER_CODE:80002C28 CMP R0, #0
    ER_CODE:80002C2A BEQ loc_80002C3C
    ER_CODE:80002C2C B loc_80002C2E
    ER_CODE:80002C2E loc_80002C2E
    ER_CODE:80002C2E LDR R0, [SP,#0xC+var_8]
    ER_CODE:80002C30 ADDS R1, R0, #4
    ER_CODE:80002C32 STR R1, [SP,#0xC+var_8]
    ER_CODE:80002C34 MOV.W R1, #0xCCCCCCCC
    ER_CODE:80002C38 STR R1, [R0]
    ER_CODE:80002C3A B loc_80002C22
    ER_CODE:80002C3C loc_80002C3C
    C5
    ER_CODE:80002B9E LDR d, =unk_2001C000
    ER_CODE:80002BA0 LDR R2, =0x4000
    ER_CODE:80002BA2 LSRS len, R2, #2
    ER_CODE:80002BA4 B loc_80002BAC
    ER_CODE:80002BA6 loc_80002BA6
    ER_CODE:80002BA6 MOV.W R2, #0xCCCCCCCC
    ER_CODE:80002BAA STMIA d!, {R2}
    ER_CODE:80002BAC loc_80002BAC
    ER_CODE:80002BAC SUBS R2, len, #0
    ER_CODE:80002BAE SUB.W len, len, #1
    ER_CODE:80002BB2 BNE loc_80002BA6
    ER_CODE:80002BB4 BX LR
    The thing is register variables increases speed and the image size gets smaller.
    Now what can i do?
    *) C6 makes everything going slower
    *) C5 with no further support
    Using C6 with optimization is not an alternative, my source is already optimized programmed and optimization makes other known problems
  • That is almost certainly due to problems in your source code.
    "my source is already optimized"
    You can't really optimise a HLL at the source level - certainly not to the point of dictating specific register usage.
    If you've tried to do stuff like that at the HLL source lever, it is quite likely counter-productive
    You should write the HLL source to be clear & maintainable, and let the compiler do the optimisation.
  • hi
    no more comments, you are definite wrong in that case.
    my code is optimized, i think you first should read some articles about programming...
    the fact is C6 creates inefficient code in comparsion to C5.
  • Come on bro, enlighten us with some of your "optimized code". Arrogance and self awareness seldom go hand in hand !
  • compiling with -O0
    Surely you're joking.
  • "My problem is, that the support for compiler 5 will end in 2020"
    Do you have a reference for this?
    Is that support from arm, Keil or both?
