How to use AT Command for Bluetooth using 8051 Microcontroller
I am using 8051 Microcontroller and connecting it with Bluetooth and LCD. I am able to send data from mobile to LCD Display and can also print pre-written lines in code on mobile Bluetooth Terminal and LCD Display. How can I write AT Commands in the code, so that I can access the GPIO Pins of Bluetooth ?
/* Port 2 rs, rw, en of LCD Port 1 LCD Output Port 3 Bluetooth
#include<reg51.h>
void Baud();
sbit rs = P2^5;
sbit rw = P2^6;
sbit en = P2^7;
void lcdcmd(unsigned char );
void lcddata(unsigned char);
void msdelay(unsigned char);
void run(unsigned char *l);
char String[10]="SCIENTECH";
void SerTx(unsigned char);
void at_command_send(unsigned char *str);
void enter();
int i;
unsigned char a;
unsigned char var_tfr;
void EINT() interrupt 4
{ a=SBUF; lcdcmd(0xcd); lcddata(a); // Put value of Serial Buffer at Port 1, which is LCD
RI=0; TI=0;
void main()
{ Baud(); lcdcmd(0x38); // 2 lines and 5 x 7 matrix lcdcmd(0x01); // Clear Display lcdcmd(0x0E); // Display on, cursor blinking lcdcmd(0x06); // Increment Cursor lcdcmd(0x80);
run("BT - Interface : "); lcdcmd(0xc0); run("Data Receive: ");
at_command_send("AT+AB GPIOConfig 2 'O'"); enter(); msdelay(1); at_command_send("AT+AB GPIOWrite 2 1"); enter(); IE=0x90; while(1) { msdelay(1); }
{ EA=0; while(*str!='\0') { TI=0; SBUF=(*str++); while(!TI); TI=0; }
} void lcdcmd(unsigned char value)
{ P1 = value; rs=0; rw=0; en=1; msdelay(10); en=0;
//void SerTx(unsigned char value1)
// SBUF=value1;
// while(TI==0);
// TI=0;
// // RI=0;
void lcddata(unsigned char value)
{ P1 = value; rs=1; rw=0; en=1; msdelay(1); en=0;
void msdelay(unsigned char time)
{ unsigned int i,j; for(i=0; i<time; i++) { for (j=0; j<1275; j++); }
{ while(*l) { var_tfr=*l++; P1= var_tfr; SBUF=var_tfr; rs=1; rw=0; en=1; msdelay(10); en=0; while(TI==0); TI=0; }
void Baud()
{ TMOD=0x20; // Timer 1, Mode 2 SCON=0x50; // Mode 1 TH1=0xFD; // 9600 TR1=1;
} void enter()
SBUF=0x0a; while(TI==0); TI=0; RI=0; SBUF=0x0d; while(TI==0); TI=0; RI=0;
                    Port 1 LCD Output
                    Port 3 Bluetooth
    #include<reg51.h>
    void Baud();
    sbit rs = P2^5;
    sbit rw = P2^6;
    sbit en = P2^7;
    void enter();
    int i;
    unsigned char a;
            a=SBUF;
      lcdcmd(0xcd);
            RI=0;
            TI=0;
    void main()
                    Baud();
                    lcdcmd(0x80);
                    lcdcmd(0xc0);
                    enter();
                    msdelay(1);
                    enter();
                    IE=0x90;
                    while(1)
                    msdelay(1);
            EA=0;
            while(*str!='\0')
                    TI=0;
                    SBUF=(*str++);
                    while(!TI);
                    TI=0;
            P1 = value;
            rs=0;
            rw=0;
            en=1;
            msdelay(10);
            en=0;
    //      SBUF=value1;
    //      while(TI==0);
    //      TI=0;
    //      // RI=0;
            P1 = value;
            rs=1;
            rw=0;
            en=1;
            msdelay(1);
            en=0;
            unsigned int i,j;
            while(*l)
                    var_tfr=*l++;
                    P1= var_tfr;
                    SBUF=var_tfr;
                    rs=1;
                    rw=0;
                    en=1;
                    msdelay(10);
                    en=0;
                    while(TI==0);
                    TI=0;
    void Baud()
            TH1=0xFD;                       // 9600
            TR1=1;
    void enter()
                    SBUF=0x0a;
                    while(TI==0);
                    TI=0;
                    RI=0;
                    SBUF=0x0d;
                    while(TI==0);
                    TI=0;
                    RI=0;
  • What BlueTooth part? What does the manual/data sheet describe?
