If statement is evaluating even though the value is 0
Processor: 8051 (AT89LP4052)
for (i=0; i<8; i++){
        if ((P1 >> i) & 1){ //if the channel is high (idle)
                P1mask &= ~(1 << i); //clear the bit
                chan_counter[i] = 0xFF; //reset the channel counter
In the debugger, when added to the Watch1 ((P1 >> i) & 1) shows 0 correctly when I switch off the port1 pins; but the code inside the {} still runs!
I can't figure out why this is not working. Another part of my code I am using
 if ((P1 | P1mask) == 0xFF) {
and it works fine.
Any tips on getting this if statement to work?
Thanks!
  • Try breaking your code down:
            unsigned char P1_Copy;
            P1_Copy = P1;
            if ((P1_Copy >> i) & 1){ //if the channel is high (idle)
    Modify that addition and see if you can determine what is going wrong.
  • Actually I tried that, and in the debugger the variable P1_Copy was fixed at its initial value (I set a breakpoint the line after P1_Copy = P1;), where P1 itself would change to reflect the actual live value. I thought that very odd.
  • I would:
    Check the define of P1
    Look at the disassembly (and step thru it) to see what's really happening.
  • Here is (a snippet of) my definitions:
    /* Byte Registers */
    sfr P1          = 0x90;            /* Port 1                                 */
    /* Bit Definitions */
    /* P1 0x90 */
    sbit P1_0       = P1^0;            /*                                        */
    OK, here is what I have done to solve the problem:
    I simplified the code by doing away with the for-loop and make 8 if statements. Each looks like this:
    if (P1_0) {
            P1mask &= 0xFE;
            chan_counter[0] = 0xFF;
    However... this suffers the same problem, the Watch window says that P1_0 is 0, but it still evaluates the if as true, grrr.
    The assembly is simple and looks correct:
       102:                 if (P1_0) {
    C:0x088C    309006   JNB      P1_0(0x90.0),C:0895
       103:                         P1mask &= 0xFE;
    C:0x088F    5310FE   ANL      P1mask(0x10),#0xFE
       104:                         chan_counter[0] = 0xFF;
    C:0x0892    7508FF   MOV      chan_counter(0x08),#0xFF
       105:                 }
    So, I thought I need to test this on the hardware, to test the simulator, and lo and behold it works as intended perfectly.
    IS THIS A BUG IN THE SIMULATOR?!
    Caveat: I used SDCC to compile for the hardware.
    Dan
