I have a problem with lpc2148 uart receiver (with interrupt)
Hello Sir,
when I use lpc2148 UART receiver interrupt then microcontroller is not receiving any value
but if I use a simple receiver then it's working correctly and receive correct data.
I'm check this code on both hardware or proteus simulator but it's not working
this is my interrupt code,
#include <lpc21xx.h>
volatile char x;
void initUart0(void);
void Uart0ISR(void) __irq;
void delay(int time)
        int i,j;
        for(i=0;i<time;i++)
          for(j=0;j<1275;i++);
int main(void)
        IO1DIR = 0xFFFF0000;
        IO0DIR = (1<<3);
        initUart0();
        while(1){
         IO1PIN=x<<16;
                delay(1);
        PINSEL0|=0x00000005;
        U0LCR = 0x83;
        U0DLM = 0x00;
        U0DLL = 19;
        U0LCR = 0X03;
        U0FCR = 0x01;
        VICVectAddr1 = (unsigned long)Uart0ISR;
        VICVectCntl1 = 0x20 | 6;
        VICIntEnable |= (1<<6);
         x      = U0RBR;
         IOPIN0 ^=(1<<3);
         VICVectAddr = 0x0;
and this is my simple code, it is working on both hardware or software correctly
volatile char x;
char uartoRec();
        int i,j;
        for(i=0;i<time;i++)
          for(j=0;j<10275;i++);
int main(void)
        initUart0();
        while(1){
                IOPIN1 = uartoRec()<<16;
        U0LCR=(1<<7);
  U0DLM = 0x00;
  U0DLL = 19;
        U0LCR=0X03;
char uartoRec()
        while(!(U0LSR&(0x01)));
        x = U0RBR;
        return x;
thank you
  • Good of you to initialize the UART with not a single comment or named constant to make a reader understand how you initialize it.
    Another thing - x is an 8-bit value and you do a 16-bit shift.
    And an ISR is also expected to look at the available flags to figure out the interrupt reason - the UART can produce interrupts for more than just reception of a character.
  • [modify] LPC2148 UART receiver interrupt code sir, I am added comment in this code, now this modified code is working on proteus but on hardware, it shows the 0xFF value of entered character
    #include <lpc214x.h>
    volatile long  x;
    void delay(int time)   //delay function
            int i,j;
            for(i=0;i<time;i++)
              for(j=0;j<10275;j++);
    void initClocks(void)
            PLL0CON = 0x01;   //Enable PLL
            PLL0CFG = 0x24;   //Multiplier and divider setup
            PLL0FEED = 0xAA;  //Feed sequence
            PLL0FEED = 0x55;
            while(!(PLL0STAT & 0x00000400)); //is locked?
            PLL0CON  = 0x03;   //Connect PLL after PLL is locked
            PLL0FEED = 0x55;
            VPBDIV   = 0x01;    // PCLK is same as CCLK i.e.60 MHz
    int main(void)
            IO0DIR = 0xFF0000;
      initClocks();    //init Clocks
            initUart0();        // init uart0
            while(1){
                    IOSET0 = x<<16;  // { ascii value set on IOPIN 16 - IOPIN 23}
                    delay(500);
                    IOCLR0 = x<<16;  // clear IOPIN
                    delay(5);
            PINSEL0 = 0x5;  /* Select TxD for P0.0 and RxD for P0.1 */
            U0LCR   = 0x83; /* 8 bits, no Parity, 1 Stop bit | DLAB set to 1 */
            U0DLL   = 78;   //baud Rate 9600 at 12MHZ
            U0DLM   = 1;
            U0FDR   = 0xF1; /* MULVAL=15(bits - 7:4) , DIVADDVAL=0(bits - 3:0)*/
            U0LCR &= 0x0F; // Set DLAB=0 to lock MULVAL and DIVADDVAL
            U0IER=0x1;     // Enable RBR interrupt
            //BaudRate is now ~9600 and we are ready for UART communication!
            long int regVal;
            regVal = U0IIR;
             x      = U0RBR;     //read data
             VICVectAddr = 0x0;
    char uartoRec()
            x = U0RBR;
            return x;
