Can I dynamically change the input clock frequency of the AT91SAM3X8E?
Background:
I'm attempting to use an AT91SAM3X8E microcontroller purchased from www.kynix.com/.../AT91SAM7S128-MU.html(for Arduino Due compatibility) to create a USB to I2SI2S interface. Most I2SI2S CODECs require a master clock that is MCLK=256*BCLKMCLK=256*BCLK where BCLK is the bit clock, which in turn is BCLK=64*FsBCLK=64*Fs. This would be trivial to generate if I was only dealing with one sample frequency, but I would like to retain compatibility for all common values (44.1kHz, 48kHz, 88.2kHz, 96kHz, 196kHz).
I plan to use the microcontroller's Synchronous Serial Controller (SSC) for this task, which it seems very well suited for.
Problem:
All of the I2SI2S clock signals must run off of a multiple of the sampling rate, which varies between two sets - multiples of 44.1kHz and multiples of 48kHz. This means that the clock driving the serial controller must be dynamically switched between two values. At first, I thought that driving the serial controller's transmit clock with the appropriate frequency would be the best option, but that doesn't allow for dynamic clock division for supporting different sampling frequencies. I concluded (perhaps incorrectly) that I need to be able to switch the master clock of the microcontroller in order to address all of these issues.
Question:
Can the AT91SAM3X8E support dynamically changing the clock that it receives on the XIN pin or would that cause run-time errors? If so, would there be a way to get around those (such as temporarily using the RC oscillator)?
0
