Stellaris ICDI debugger kicks the program flow to unknown
I'm using uvision 5.
I created a project for TM4C123GH6.
Uvision generated two files, startup_TM4C123.s and system_TM4C123.s.
I added a file main.c. In main I wrote the statements:
int a,b,c;
a= 100;
b= 200;
c= a+b;
return 0;
It compiles fine. Debugging simulation works fine. When I select
Stellaris ICDI for debugging, the debugger goes crazy, kicks the program flow to unknown.
Nothing wrong with my board, I used different vendor's IDE and it worked fine.
What is the problem here?
  • What on earth does that mean?
    Please be specific!
    Note that your code effectively does nothing - so is likely to be completely optimised away.
    And what do you expect this to do in an embedded system:
    return 0;
  • Even Though inside main() I wrote a program to control LEDs or copy a program from the internet when I select for Settaris ICDI debugging, the debugger stops momentarily at the break point and disappears. Anyone has a demo program that works with Settaris ICDI debugger?
