compile time issues with c++ source code
Hi Support Team,
I am using the Azrec bar code open source c++ code to build a library for AT91RM9200 micro controller. First is tried to build the open source code on Microsoft Visual Studio 2015 and I could build the code successfully but when I am trying to build the same code on the Keil uvision 5 IDE with legacy device database installed I am getting the error for the line-
typedef std::vector<std::iterator_traits<DataIterator>::value_type> buffer_type;
as
error: #757: nontype "std::iterator_traits<_Iterator>::value_type [with_Iterator=DataIterator]" is not a type name
I have already set DataIterator a type name in the source as-
template <typename DataIterator>
How can I resolve the issue please let me know ASAP. I suppose there is some compiler support issue in Keil 5 as the same code is working fine with the Microsoft Visual Studio 2015.
Please let me know if I need to install / set any compiler options / parameters. I had checked with the --cpp, --cpp11 compiler options but still I am getting the same issue.
Thanks & Regards,
Amit
0
