Hi fellow programming gurus.
I've come up against a very hard problem and i want some advise.
My problem is that i need to generate a series of random numbers. I know that they are not really random (the term is deterministic) but i have created a really clever idea to improve the starting point of the sequence. I will seed the generator with a random number.
like this
<pree>
srand ( rand () ) ;
but it is not working properly. Can you help me fix it?
Gosh I really needed that. Thank you!
pubs.opengroup.org/.../srand.html
If rand() is called before any calls to srand() are made, the same sequence shall be generated as when srand() is first called with a seed value of 1.
Some newer MCUs are equipped with True Random Number Generator, like Freescale Kinetis MCUs. Are the True Random Number Generator useful?
