Hi! I have MT29F32G08CBACA Nand Flash device, and I need wear leveling. This device have Page Size = 4096 user + 224 spare bytes. But in FS_Config_NAND_0.h a can chose only 4096+ 128. Will this device work with the Keil File System?
You can manually define page size in config file and you should be ok.
#define NAND0_PAGE_SIZE 4320
Devices with bigger spare area usually require 4-bit ECC per 512 bytes. This can be only supported by hardware, so check your device and hardware ECC support before using such device.
Hi. I difined NAND0_PAGE_SIZE 4320. I'm trying to do next code, drive N0 not formatted, it's okey becose never formatted before. And when I do: stat = fformat ("N0:", "/LL");, I get error and stat = 8.
static void Filesystem_Init (void) { fsStatus stat; /* Initialize and mount drive "N0" */ stat = finit ("N0:"); if (stat == fsOK) { stat = fmount ("N0:"); if (stat == fsOK) { printf ("Drive N0 ready!\n\r"); } else if (stat == fsNoFileSystem) { /* Format the drive */ printf ("Drive N0 not formatted!\n\r"); cmd_format (); } else { printf ("Drive N0 mount failed with error code %x\n\r", stat); } } else { printf ("Drive N0 initialization failed!\n\r"); } } static void cmd_format (void) { fsStatus stat; stat = fformat ("N0:", "/LL"); if (stat == fsOK) { printf ("Format completed.\n\r"); } else { printf ("Formatting failed. Code = %d\n\r", stat); } }
About ECC: Minimum required ECC 24-bit ECC per 1080 bytes of data. It's from DS.
