Hello everybody! Please help with such a problem. I try to create a static array of 8-bit values, but when I launch the program, for some reason, irrespective of which values I write, after startup the array has all the values nothing, but zeros. Here is the code:
This is how I state the array:
int main(void) { static char string[10]={1,3,7,15,31,63,127,0,0,0}; ...
After the program is launched, I look at the memory and see that the array has all the values set to zero.
Please help!
