error C132: 'interrupt1': not in formal parameter list
Good Day, i am a novice programmer and am trying to compiler a code for micro controller AT89C52 using a reference code but i keep running to an error which seems to be causing other errors.
        #include <reg52.h>        //header file
        sbit TSTART_1 = P1^2;
        sbit TSTART_2 = P1^3;
        sbit INP_1 = P1^0;
        sbit INP_2 = P1^1;
        sbit door_en = P2^5;
        sbit door_in1 = P2^4;
        sbit door_in2 = P2^1;
        sbit door_sw1 = P2^2;
        sbit door_sw2 = P2^3;
        sbit in1 = P3^1;
        sbit in2 = P3^2;
        sbit en1 = P3^0;
        sbit en2 = P3^3;
        sbit in3 = P3^4;
        sbit in4 = P3^5;
        sbit BUZZER = P3^6;
        sbit digit1 = P2^7;
        sbit digit2 = P2^6;
        sbit red_led = P1^4;
        sbit green_led = P1^5;
        sbit seg_A = P0^0;
        sbit seg_B = P0^1;
        sbit seg_C = P0^2;
        sbit seg_D = P0^3;
        sbit seg_E = P0^4;
        sbit seg_F = P0^5;
        sbit seg_G = P0^6;
        bit time_count_flag = 0x01;
        void delay1();
        void delay_3sec();
        void delay_buzzer();
        void timer0_init();
        void timer1_init();
        void display_led(unsigned char);
        int time_count=0, count, count1=0;
  • I could post the full code due to character limits, here is the continuation
            void main()
                    P1=0XFF;
                    BUZZER=0;
                    P0=0X00;
                    timer0_init();
                            while(1)
                                    while(1)
                                                    if(TSTART_1==0)
        red_led=1;
        green_led=0;
        en1=0;
        en2=0;
        BUZZER=1;
        delay_buzzer();
        BUZZER=0;
        delay1();
        door_en=1;
        door_in1=1;
        door_in2=0;
        delay1();
        door_en =0;
        timer1_init();
                                    while(1)
                                                    if(INP_1==1)
        while(INP_2 ==1);
        count = count+1;
        if(count >=25)
        BUZZER=1;
        delay_buzzer();
        BUZZER=0;
        delay_3sec();
        door_en=1;
        door_in1=0;
        door_in2=1;
        delay1();
        door_en=0;
        delay1();
        if(INP_2 ==1)
        while(INP_1==1);
        count = count-1;
        if(count <= 0)
        count = 0;
        delay1();
                                                            if(time_count_flag ==1)
        TR1=0;
        time_count_flag = 0;
        TH1=0X00;
        TL1=0X00;
        ET1=1;
        TR1=1;
        BUZZER=1;
        delay_buzzer();
        BUZZER=0;
        delay_3sec();
        door_en=1;
        door_in1=0;
        door_in2=1;
        while(door_sw2==1);
        door_en=0;
        }//end while
  • Continuation
        BUZZER=1;
        delay_buzzer();
        BUZZER=0;
        delay_3sec();
        door_en=1;
        door_in1=0;
        door_in2=1;
        while(door_sw2==1);
        door_en=0;
        green_led=1;
        red_led=0;
        en1=1;
        in1=1;
        in2=0;
        en2=1;
        in3=1;
        in4=0;
        while(TSTART_2==1);
        while(TSTART_2==0);
        break;
                                                            }//end if
                                                    }//end while
        }  //end while
  • Ignore this post, found the problem.... can the mods delete this post
