Hello, I am trying to implement multi-channel adc with dma. I am using STM32F746 Discovery Board. But seems not working. Here is my initialization functions :
First, here is my buffer that fills with ADC Channels data.
// TOTAL_TRANSFER_WORDS is defined as ((ADC_CHANNEL_COUNT) * (MOVING_AVERAGE_WINDOW_SIZE)) // and ADC_CHANNEL_COUNT defined as 5, als MOVING_AVERAGE_WINDOW_SIZE defined as 10. uint16_t volatile total_adc_readings[TOTAL_TRANSFER_WORDS] = { 0x00 };
static void adc_initialization(void) { ADC_HandleTypeDef adc_handle; ADC_ChannelConfTypeDef sConfig; // USED_ADC is actually ADC3 adc_handle.Instance = USED_ADC; adc_handle.Init.Resolution = ADC_RESOLUTION_12B; adc_handle.Init.ClockPrescaler = ADC_CLOCK_SYNC_PCLK_DIV8; adc_handle.Init.ScanConvMode = ADC_SCAN_ENABLE; adc_handle.Init.ContinuousConvMode = ENABLE; adc_handle.Init.DiscontinuousConvMode = DISABLE; adc_handle.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE; adc_handle.Init.ExternalTrigConv = ADC_EXTERNALTRIGCONV_T1_CC1; adc_handle.Init.DataAlign = ADC_DATAALIGN_RIGHT; adc_handle.Init.DMAContinuousRequests = ENABLE; adc_handle.Init.NbrOfDiscConversion = 0; adc_handle.Init.NbrOfConversion = ADC_CHANNEL_COUNT; if ( HAL_ADC_Init(&adc_handle) != HAL_OK ) { while ( 1 ) { /* ADC INITIALIZATION FAILED */ } } // Common channel configurations sConfig.Offset = 0; sConfig.SamplingTime = ADC_SAMPLETIME_480CYCLES; // channel 0 configurations sConfig.Rank = 1; // SYSTEM_SUPPLY_CHANNEL is actually ADC_CHANNEL_4 sConfig.Channel = SYSTEM_SUPPLY_CHANNEL; if ( HAL_ADC_ConfigChannel(&adc_handle, &sConfig) != HAL_OK ) { while ( 1 ) { /* ADC INITIALIZATION FAILED */ } } // channel 1 configurations sConfig.Rank = 2; // EXT_BAT_SUPPLY_CHANNEL is actually ADC_CHANNEL_5 sConfig.Channel = EXT_BAT_SUPPLY_CHANNEL; if ( HAL_ADC_ConfigChannel(&adc_handle, &sConfig) != HAL_OK ) { while ( 1 ) { /* ADC INITIALIZATION FAILED */ } } // channel 2 configurations sConfig.Rank = 3; // MAIN_BAT_SUPPLY_CHANNEL is actually ADC_CHANNEL_6 sConfig.Channel = MAIN_BAT_SUPPLY_CHANNEL; if ( HAL_ADC_ConfigChannel(&adc_handle, &sConfig) != HAL_OK ) { while ( 1 ) { /* ADC INITIALIZATION FAILED */ } } // channel 3 configurations sConfig.Rank = 4; // this is used for internal temperature sensor. sConfig.Channel = ADC_CHANNEL_13; if ( HAL_ADC_ConfigChannel(&adc_handle, &sConfig) ) { while ( 1 ) { /* ADC INITIALIZATION FAILED */ } } // channel 18 configurations sConfig.Rank = 5; // RC_BAT_SUPPLY_CHANNEL is actually ADC_CHANNEL_7 sConfig.Channel = RC_BAT_SUPPLY_CHANNEL; if ( HAL_ADC_ConfigChannel(&adc_handle, &sConfig) != HAL_OK ) { while ( 1 ) { /* ADC INITIALIZATION FAILED */ } } // start dma transfer if ( HAL_ADC_Start_DMA(&adc_handle, (uint32_t*)&total_adc_readings, TOTAL_TRANSFER_WORDS) != HAL_OK ) { while ( 1 ) { /* ADC INITIALIZATION FAILED */ } } }
And here is my msp init function :
void HAL_ADC_MspInit(ADC_HandleTypeDef *hadc) { GPIO_InitTypeDef GPIO_InitStructure; static DMA_HandleTypeDef hdma_adc; // Enable GPIO Clock, ADC Clock, DMA2 Clock respectively ADC_GPIO_PORT_CLK_ENABLE(); // this is actually __HAL_RCC_GPIOF_CLK_ENABLE() ADC_CLK_ENABLE(); // this is actually __HAL_RCC_ADC3_CLK_ENABLE() DMA_CLK_ENABLE(); // this is actually __HAL_RCC_DMA2_CLK_ENABLE() // Configure ADC Pins // VSYS_LEVEL_ADC_PIN is actually GPIO_PIN_6 // VBAT_EXT_LEVEL_ADC_PIN is actually GPIO_PIN_7 // VBAT_MAIN_LEVEL_ADC_PIN is actually GPIO_PIN_8 // VBAT_RC_LEVEL_ADC_PIN is actually GPIO_PIN9 // and lastly ADC_GPIO_PORT is actually GPIOF GPIO_InitStructure.Pin = ( VSYS_LEVEL_ADC_PIN | VBAT_EXT_LEVEL_ADC_PIN | VBAT_MAIN_LEVEL_ADC_PIN | VBAT_RC_LEVEL_ADC_PIN ); GPIO_InitStructure.Mode = GPIO_MODE_ANALOG; GPIO_InitStructure.Pull = GPIO_NOPULL; HAL_GPIO_Init(ADC_GPIO_PORT, &GPIO_InitStructure); // Configure DMA Streams // ADC_DMA_STREAM is actually DMA2_Stream0 // and lastly ADC_DMA_CHANNEL is DMA_CHANNEL_2 hdma_adc.Instance = ADC_DMA_STREAM; hdma_adc.Init.Channel = ADC_DMA_CHANNEL; hdma_adc.Init.Mode = DMA_CIRCULAR; hdma_adc.Init.Direction = DMA_PERIPH_TO_MEMORY; hdma_adc.Init.FIFOMode = DMA_FIFOMODE_DISABLE; hdma_adc.Init.PeriphInc = DMA_PINC_DISABLE; hdma_adc.Init.MemInc = DMA_MINC_ENABLE; hdma_adc.Init.PeriphDataAlignment = DMA_PDATAALIGN_WORD; hdma_adc.Init.MemDataAlignment = DMA_MDATAALIGN_WORD; hdma_adc.Init.Priority = DMA_PRIORITY_HIGH; hdma_adc.Init.FIFOThreshold = DMA_FIFO_THRESHOLD_HALFFULL; hdma_adc.Init.MemBurst = DMA_MBURST_SINGLE; hdma_adc.Init.PeriphBurst = DMA_PBURST_SINGLE; HAL_DMA_Init(&hdma_adc); /* Associate the initialized DMA handle to the ADC handle */ __HAL_LINKDMA(hadc, DMA_Handle, hdma_adc); }
after all, when I debugging the code, total_adc_readings is always filled with 0x00. It means that, ADC initialization is false I think.
But I can not find the problem with the initialization code. Could you help me for finding problem in the initialization code. Thanks for answers. Best regards.
