I have template class for Uart. For initialization of interrupt I use global function which is defined as extern "C", but my interrupt is never called. I cannot find whats wrong.
/* header file */ extern "C" void USART0_RX_vect (void) __irq; template <int RXBuf, int TXBuf> class Uart { public: void initInterrupt (uint32_t a_baudrate, LPC_UART_TypeDef* a_channel) { init (a_baudrate, a_channel); if (a_channel == LPC_UART0) { LPC_VIC->IntEnable |= INT_EN_UART0; //enable UART0 int LPC_VIC->IntSelect = 0x00000000; LPC_VIC->VectCntl8 = IRQ_SLOT_UART0 | IRQ_SLOT_ENABLE; LPC_VIC->VectAddr8 = (unsigned long) USART0_RX_vect; } else if (a_channel == LPC_UART1) { LPC_VIC->IntEnable |= INT_EN_UART1; //enable UART1 int LPC_VIC->IntSelect = 0x00000000; LPC_VIC->VectCntl7 = IRQ_SLOT_UART1 | IRQ_SLOT_ENABLE; LPC_VIC->VectAddr7 = (unsigned long) USART1_RX_vect; } a_channel->IER |= UART_RDA_ENABLE | UART_RX_STAT_ENABLE; } }; /* cpp file */ void USART0_RX_vect (void) __irq { g_Uart->receiverHandler (LPC_UART0); LPC_VIC->VectAddr = 0x0; }
