I am playing around with the USBMem example for the MCB214x Board. Using a hex editor I found the offset (0x800) of the data area on the RAM and wrote the following code to change the data in the readme.txt file.
I created a counter variable and it increments when I press switch sw1. I want to store its value into the file every time I push the switch.
class variables
U8 * offset = &Memory[0x800]; int counter=0;
now inside main function I wrote following code
PINSEL0 = PINSEL0|(0<<15); IO0DIR = (0<<15); while (1){ if(!SW1){ counter = counter+1; LED_On(1<<16); *offset = counter; //line 1 offset +=4; // line 2 } else {LED_Off(1<<16);} };
The problem is that when I run the code on the board the led remains on after I have pressed the switch! However When I comment out the lines "line 1" and "line 2" and run the code the led switches on and off perfectly fine!
can anybody explain me whats going on wrong here ?
