Excuse me, I can't speak english very well . I use a Microcontroller ST10F276 and keil compiler in my project . My project is needed about 500 Kbyte IFASH for code and 6 or 8 Kbyte IRAM or XRAM for variable. Microcontroller ST10F276 have a 2 Kbyte 16 bit wide IRAM, a 66 Kbyte 16 bit wide on chip XRAM, a 512 Kbyte 16 bit wide on chip internal Flash (IFLASH) and a 320 Kbyte 16 bit wide on chip extended Flash (XFLASH). but when I compile my project, keil compiler prepare this error :main.c(25746): error C8: code size exceeds 64K .
Please see my project setting : Options for Target 'Taret 1' tab - Target
STMicroelectronics ST10F276 Select : Use On chip ROM(832) Select : Use On chip CAN+XRAM(0xE000 - 0xE7FF) Select : Use On chip XRAM(0xF0000 - 0xFFFFF) Clock (MHz) : 64.0 Memory Model : Medium 'near' data 'far' funcs Operating System : None Data Threshold : near 6 Near Memory : 16 KB RAM, 16 KB ROM
External Memory : Start Size #1 ROM 0x00 0x8000 #2 RAM
Please help me to eliminate this error : main.c(25746): error C8: code size exceeds 64K in my project.
<b/>
