Hello!!!!!!!!!
I'm using an AT91SAM9X35 Board..and i wanted to load a application code to DDR2SDR(Secondary RAM) directly through keil download option or through sam-ba software....is it possible?????????????
Thank you!!!
You'd likely need to make a debugger script (.INI) which initializes the pins, the memory controller and the SDRAM, and then LOAD %L to code into the memory. Uncheck "Load Application at Startup", and point to the initialization file.
Several of ATMEL boards have DebugInSDRAM.ini type examples.
Thank You Pier Sorry for late Response.
1) I'm not getting this --> LOAD %L to code into the memory
2) I'm Refereeing Blinky_led program given in KEIL ATMEL software package.They have given .ini file for both internal RAM and EXT. SDRAM. as you said In the .INI file of the Ext.SDRAM they are the initialized the Pins and Ext.SDRAM ,Now I wanted to load my blinky led application code directly to SDRAM. I Uncheck "Load Application at Startup", and point to the initialization file.
3) Similarly i not able load my led application code internal RAM also.
I'm getting FLASH DOWNLOAD FAILED ERROR when i'm going to Downlod the code.
Rebuild target 'SAM9X35 Ext SDRAM' assembling SAM9X35.s... compiling Blinky.c... linking... Program Size: Code=868 RO-data=40 RW-data=4 ZI-data=204 ".\Ext_SDRAM\Blinky.axf" - 0 Error(s), 0 Warning(s). Load "C:\\Users\\Tejas\\Desktop\\blinky_led\\Blinky\\Ext_SDRAM\\Blinky.axf" ProjectFile = C:\Users\Tejas\Desktop\blinky_led\Blinky\JLinkArm_SAM9X35 Ext SDRAM.ini Device = SAM9X35 Info: Device "AT91SAM9X35" selected (0 KB flash, 0 KB RAM). VTarget = 3.293V Info: TotalIRLen = 4, IRPrint = 0x01 Info: CP15.0.0: 0x41069265: ARM, Architecure 5TEJ Info: CP15.0.1: 0x1D152152: ICache: 16kB (4*128*32), DCache: 16kB (4*128*32) Info: Cache type: Separate, Write-back, Format C (WT supported) Info: CP15.0.0: 0x41069265: ARM, Architecure 5TEJ Info: CP15.0.1: 0x1D152152: ICache: 16kB (4*128*32), DCache: 16kB (4*128*32) Info: Cache type: Separate, Write-back, Format C (WT supported) DLL version V4.62, compiled Jan 25 2013 15:19:47 Firmware: J-Link ARM V8 compiled Aug 26 2015 15:08:21 Hardware: V8.00 Hardware-Breakpoints: 2 Software-Breakpoints: 8192 Watchpoints: 0 Found 1 JTAG device, Total IRLen = 4: Id of device #0: 0x0792603F ARM9 identified. JTAG speed: 1000 kHz Info: CP15.0.0: 0x41069265: ARM, Architecure 5TEJ Info: CP15.0.1: 0x1D152152: ICache: 16kB (4*128*32), DCache: 16kB (4*128*32) Info: Cache type: Separate, Write-back, Format C (WT supported) Using adaptive clocking instead of fixed JTAG speed. Include "C:\\Users\\Tejas\\Desktop\\blinky_led\\Blinky\\Clock.ini" /******************************************************************************/ /* Clock.ini: Initialize clock to Main Oscillator clock */ /******************************************************************************/ // <<< Use Configuration Wizard in Context Menu >>> // /******************************************************************************/ /* This file is part of the uVision/ARM development tools. */ /* Copyright (c) 2005-2010 Keil Software. All rights reserved. */ /* This software may only be used under the terms of a valid, current, */ /* end user licence from KEIL for a compatible version of KEIL software */ /* development tools. Nothing else gives you the right to use this software. */ /******************************************************************************/ DEFINE LONG PMC; PMC = 0xFFFFFC00; _WDWORD(PMC+ 0x20, 0x01370701); // CKGR_MOR: Enable main oscillator _sleep_(200); // Wait for stable Main Oscillator _WDWORD(PMC+ 0x80, 0x00000001); // PMC_PLLICPR: Charge Pump Current _sleep_(200); // Wait for stable Main Oscillator _WDWORD(PMC+ 0x28, 0x202A4601); // CKGR_PLLAR: Configure PLL A _sleep_(200); // Wait for stable Main Oscillator _WDWORD(PMC+ 0x30, 0x00000010); // PMC_MCKR: PRES field _sleep_(200); // Wait for Main Master Clock ready _WDWORD(PMC+ 0x30, 0x00000212); // PMC_MCKR: all fields _sleep_(300); // Wait for Main Master Clock ready No Algorithm found for: 20000000H - 2000038FH Erase skipped!
