I'm using an AT91SAM9X35 controller.i wanted to load a application code in evaluation board through Download option(i.e in flash ), but i'm getting an below error.i'm using an ATMEL SAM-ICE DEBUGGER to load the code.
Load "C:\\Users\\Tejas\\Desktop\\blinky_led\\Blinky\\Int_RAM\\Blinky.axf" ProjectFile = C:\Users\Tejas\Desktop\blinky_led\Blinky\JLinkArm_SAM9X35 Int RAM.ini Device = SAM9X35 Info: Device "AT91SAM9X35" selected (0 KB flash, 0 KB RAM). VTarget = 3.313V Info: TotalIRLen = 4, IRPrint = 0x01 Info: CP15.0.0: 0x41069265: ARM, Architecure 5TEJ Info: CP15.0.1: 0x1D152152: ICache: 16kB (4*128*32), DCache: 16kB (4*128*32) Info: Cache type: Separate, Write-back, Format C (WT supported) Info: CP15.0.0: 0x41069265: ARM, Architecure 5TEJ Info: CP15.0.1: 0x1D152152: ICache: 16kB (4*128*32), DCache: 16kB (4*128*32) Info: Cache type: Separate, Write-back, Format C (WT supported) DLL version V4.62, compiled Jan 25 2013 15:19:47 Firmware: J-Link ARM V8 compiled Aug 26 2015 15:08:21 Hardware: V8.00 Hardware-Breakpoints: 2 Software-Breakpoints: 8192 Watchpoints: 0 Found 1 JTAG device, Total IRLen = 4: Id of device #0: 0x0792603F ARM9 identified. JTAG speed: 1000 kHz Info: CP15.0.0: 0x41069265: ARM, Architecure 5TEJ Info: CP15.0.1: 0x1D152152: ICache: 16kB (4*128*32), DCache: 16kB (4*128*32) Info: Cache type: Separate, Write-back, Format C (WT supported) Using adaptive clocking instead of fixed JTAG speed. No Algorithm found for: 00000000H - 0000065FH Erase skipped!
